Wheel Bearings
Old Sep 24, 2021 | 07:16 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Wheel Bearings
Anyone do the wheel bearings themselves?
How hard?
Old Sep 25, 2021 | 01:02 PM
chassis's Avatar
2017 GLE350 4MATIC
I have done wheel bearings, not on an MB, and only hub+bearing units. Hub+bearing units are straightforward.
Front wheel bearings on 164 and rear wheel bearings on 164 and 166 are a press-in style and in my opinion a new knuckle/upright with new hub+bearing is the way to go. Do do otherwise requires you to have a bench top arbor press and the proper mandrels for the arbor press.
WIS calls for knuckle removal for the front wheel bearing on 164, then the arbor press work is required, same as for the rear axle.
Double check for your vehicle fitment:
Amazon Amazon
Old Sep 25, 2021 | 04:23 PM
N_Jay's Avatar
WIS often shows the hardest way to do anything.
I have not even seen spindle assemblies, but plenty selling bearings and kits.
Not sure why a regular bearing puller will not work, but hoping to find someone with hands on experience.
Old Sep 25, 2021 | 06:41 PM
chassis's Avatar
2017 GLE350 4MATIC
The bearing itself is held in place in the knuckle by a snap ring.
After removing the caliper and rotor, the axle nut needs removed and the axle shaft pressed out.
Then wheel hub needs to be first pressed out of the bearing. The hub needs to be pressed out from the inner side, i.e. from the axle shaft side.
Then the snap ring removed. This is trivially easy.
Then the bearing pressed out of the knuckle, again from the inside pressing towards the wheel/tire side.
All of the WIS photos show a knuckle on a bench with a press and mandrels/arbors.
There are probably a number of ways to accomplish the above, the easiest and most precise in my view is on a bench with an arbor press and the proper mandrels. Or replace with a "loaded knuckle" assembly.
Old Sep 25, 2021 | 06:52 PM
E55Greasemonkey's Avatar
This place is a joke.
You'll need to remove the spindle from the car, and use a hydraulic press to R+R the bearings. You'll need some special tools and there is plenty that can and will go wrong your first time. You'll likely destroy one or more new bearings and maybe the hubs while you are trying. I charge 5 hours per front corner, 6 for each rear corner in a fully equipped shop with a lift and air tools. If your car is rusty you'd better pray to whichever imaginary being in the sky you worship.
This is not a DIY project in your driveway.
Old Sep 25, 2021 | 11:01 PM
N_Jay's Avatar
Why do the rears take more time?
I have seen one video using a bearing puller on the car.
Any one know a good source for loaded hub carriers.
I think I have a ( or both) rears to do.
Old Sep 26, 2021 | 12:35 AM
Because you have to deal with the parking brake and fight with the link arms under tension.
I've never seen loaded carriers for MB. It would be cost prohibitive anyhow, and most of the work here is pulling them off the car.
Old Sep 26, 2021 | 08:10 AM
Pmanc's Avatar
2012 gl450
Looks like it’s a big job. How do you know when you need a new wheel bearings?
Old Sep 26, 2021 | 09:32 AM
chassis's Avatar
2017 GLE350 4MATIC
Typically a humming or growling sound. Easy to make it increase or decrease in volume with braking or cornering.
Old Apr 15, 2022 | 10:41 AM
not2fast's Avatar
In the market
Does the magnetic side go in facing the axle or wheel?
Old Apr 15, 2022 | 03:09 PM
Look at the hole where the speed sensor sits. The bearing has two sides, one with a metal grease shield and the other with a plastic grease shield. The plastic side goes to the sensor.
Old Apr 18, 2022 | 12:44 PM
atraudes's Avatar
2011 E350 Wagon, 2010 GL450
I've done the front bearings and I wouldn't want to do it with the knuckle on the car. It's not a huge deal to get the knuckle off and you'd have to remove the CV axle anyway (assuming you have 4matic). I used my press and it was fairly straightforward (compared to replacing the control arm bushings, anyway ). You absolutely will destroy the bearing when pushing the hub out, but on that note you'll also need a bearing puller kit. When you push the hub out the bearing race will come with it and the bearing puller kit is the way to remove the bearing race from the hub. There are other ways to do it like using a dremel to slowly cut through it but I wasn't comfortable doing that. Your call. You could also just buy new hubs but they cost more than the kit so...
Old Apr 23, 2022 | 01:11 AM
wease206's Avatar
W215/X164/C124
https://m.youtube.com/watch?v=bory98ClEZk
