X164 GL550 LED Fog Light canbus error, need resistors?
https://www.amazon.com/NEX-Resistor-...054169039&th=1
Power = voltage squared divided by resistance
6 ohm on 14V will dissipate 196/6 watts = 33W
This should be more than sufficient. Your LED bulbs probably dissipate around 30W, and 30 + 33 = 63W. The CAN bus has a tolerance for low current; it does not demand that the bulb be full power. I found that small (1W) LED bulbs for the marker lights work fine with a 100 Ohm resistor; this is just adding about 1.5W to make about half the current the bus is looking for. So you could probably get away with a higher resistance resistor than 6 ohm, but it will be a matter of trial and error to figure out what works. I happened on the 100 ohm resistor when I accidentally ordered it instead of lower resistance.
The resistor you are looking at is running at over 50% of rating, which is a bit uncomfortable. Make sure you put it in a well ventilated location. But the fog lights will probably be used in cool conditions, so that would help.
I'd be more inclined to try a 10 to 20 ohm resistor.
