2007 GL450 Radio Issue
Old Jan 4, 2022 | 06:46 PM
Zsilver's Avatar
GL450
I have a 2007 GL450 and my radio will work perfectly for a few minutes then the sound cuts off, any ideas on what the problem is?
Old Jan 4, 2022 | 08:34 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Water in your dash.
At least that’s what causes mine to cut out intermittently.
Old Jan 5, 2022 | 10:08 AM
Miguk_Saram's Avatar
'07 GL450
Is it just the Radio, or are other inputs affected as well (CD, Sat, Nav)?
If it's just the radio then you likely have a circuit board issue on the Head Unit. Test/swap with a known-good head unit to confirm.
If it affects all other inputs then you check your Amplifier for water intrusion/damage (it's located under the driver's seat carpeting).
