USA Comand NGT2.5 replace to NGT2.5 ECE version
Old Jan 8, 2022 | 11:09 AM
Odir's Avatar
2012 GL550 & 2018 GLC300
hi,
ive replaced whole comand unit in my X164 USA to same version but ECE - i want get the fully working FM radio.
but ive guess i need some antene fix to do. for now comand is working fine, navigation aux etc - the onlu thing is completly no FM radio signal.
Xentry said thers both antenas wire not giving signal.
do i need replace all antenas set the one under the headliner? or thers some easiest way to fix it?
im looing fos some good described solution but looks there isnt any at the internet.
maybe someone can share his expirience about that kind of upgrade?
Derek.
Old Jan 21, 2022 | 09:19 PM
Max Blast's Avatar
NGL450 w/EORP, S550
One thing to check first, is that The FM band in the US works on odd digits (f.ex Radio Hot 100 on 100.5) and the FM band in Europe works on even digits (f.ex Radio Hot 100 on 100.6). Does your new tuner let you work evens when tuning manually?
I do not know if US and EC Comand units have a different option code in the master list - there are only two listed, 512 and 527 and enter or not teby are electronically different I don’t know.
