Windshield wiper spray
Hi I have a 2012 GL 450 when I spray my front windows to get washed water is coming out of the black Reservoir and also the nozzle. I will show you a picture anybody have any ideas as to what I can do thanks.
But if you're talking about the air grill, then you likely have a split in the fluid hose. Open the hood and watch as you (or someone) activates the washer.
You probably have a broken hose connector that sits right under that grill. I just put a band clamp around it when mine split and started spraying through the grill. The hose is $50ish if you'd rather replace it.
