Gasoline
Old Jun 4, 2022 | 11:35 PM
Pmanc's Avatar
2012 gl450
Gasoline
Hi everyone I have a 2012 GL 450 I have been getting super gasoline all the time is it OK if I alternate get super one time and then regular the next time??
Old Jun 5, 2022 | 01:34 AM
Max Blast's Avatar
NGL450 w/EORP, S550
It’ll run fine on lower octane fuels but will pull timing if it senses knock which may reduce full power. What you’re proposing is nothing to worry about.
Old Jun 5, 2022 | 09:45 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
I ran regular in mine for around 200k miles. If you are towing or drive aggressively all the time, you should stick with premium. Just cruising on the hwy, regular is the way to go.
Old Jun 5, 2022 | 10:14 AM
Pmanc's Avatar
2012 gl450
thanks
Old Jun 5, 2022 | 12:30 PM
Tsumi's Avatar
2006 R500
I remember reading a while back that someone used a scan tool to watch timing on their 5.0 M113 engine and the only time it pulled timing was under high load on 95+ days (think maintaining highway speed going up steep roads). M113 has a compression ratio of 10:1 while M273 is 10.7:1. You're most likely fine running regular as long as you're not running hard, especially on hot days.
Old Jun 5, 2022 | 12:40 PM
mglsite's Avatar
GL450
I was coming on here to see if anyone is still using premium and at $5.49 a gallon this morning I will be using regular for a while. And the last long trip we took in our 2012 GL450 it actually got right at 20 mpg on it going the posted speed limit.
Old Jun 5, 2022 | 12:44 PM
Tsumi's Avatar
2006 R500
Cheapest premium I can get around here is $6.49 while regular is $6.09. I'm lucky that I can expense most of my fuel usage to my company.
Old Jun 5, 2022 | 01:33 PM
BlownV8's Avatar
I run it in all mine while under warranty since I don't want any excuse for a denial. When warranty runs out, it's regular for the NA engines but I stay with premium for the bi-turbo engines.
Old Jun 7, 2022 | 05:43 PM
eric_in_sd's Avatar
2007 GL450
Here is a simple test whether the gasoline is bad for the motor. Run a full tank of one gas, normal driving, and monitor the mileage. You can use the trip computer; I used actual pump volume and miles driven.
Ditto for the other gas. Try to keep all else equal.
I did this for a thousand miles on super and then on regular. The mileage was actually slightly higher with the regular. If the knock sensor is being triggered, and the timing retarded as a result, you should see lower fuel economy.
Note I later found that the ECU has a fuel octane setting in it, possibly the result of a learning process on the part of the motor. I suppose it would make sense to change the setting in the ECU to whatever the fuel is if doing a test. This setting is accessible via my Autel MP808; I doubt any non bidirectional tools could change the setting.
.It is possible I could get better performance with 91 or 93 octane and the ECU set appropriately - but I get more-than-adequate mileage (20 mpg at freeway + country road, 40 mph average) and power, so I think I have bigger fish to fry.
Old Jun 12, 2022 | 09:26 PM
BenzBallin's Avatar
R350 2008 4Matic Gasoline
How do you Like your Autel ?? is it the Maxicom 808 ?
