Broken Down in Phoenix - Suggestions???
So anyway, soliciting suggestions for shops that are honest and great at diagnosing. They're in the Scottsdale area, so that's best, but greater PHX suggestions are appreciated. Also depends on who has the availability to see them ASAP which trumps things. Any reason that a MB dealer should be considered, and if so, which one in the area would be recommended? Tech Plus looks pretty highly recommended on Google: https://techplusautomotive.com/merce...ir-scottsdale/ so that's my starting spot.
And yes, it was indeed 98F at 10:00 at night. Gotta' love Phoenix in the summer!
THANKS!
I experience a similar issue during the winter. Every winter, or when temperature drops below say, about 50 degrees.... not sure what causes this, but definetly temperature related.
I have been able to circumvent the issue by removing the key from the ignition, re-starting the vehicle, then trying to shift without my foot on the break.. push the lever to the Drive and Reverse positions with your foot off the pedal (not just a tap, hold it for a second or so), you should hear the tranny click. Do that a couple of times, then try shifting the proper way (with your foot on the pedal). You might need to hold the lever in place a little longer than usual.
FYI, here's the best vid I found on disabling the ESP into dyno mode: Not a X164 chassis, but same general layout:
Dyno-mode... engaged! But didn't help
Torx screw was checked and is tight
Voltage was checked at jump terminals and was 12.6V, charging at 13.8V. Starts fine, just won't get in gear
Looks like a AAA call in the morning. Still wondering if anyone can confirm or recommend a repair shop in Scottsdale. Also if this sounds like a situation best handled by a dealer, please let me know... while I would prefer to not spend that extra money, I also want it handled right!
PHX temps at 10:30 this morning^^^
Right now looks like these are three good ones, all in the same general area:
Bimmer-Benz
Goody's - personal recommendation!
Tech Plus - (opens @ 7:30!)
Shot in the dark, but they have a perfect 5.0 rating over 628 reviews, so fingers crossed! They seemed nice on the phone!
Oh, and after switching it to Dyno-Mode(!) the battery died.
I really like this shop, Scottsdale European Service! They did a thorough inspection and really noted all the problems on the vehicle then sent photos of them in a little album. I wish I could send them our five series to get worked on, as nobody near me can seem to figure it out (two indys and the dealer!).
They also noted front upper control arm bushings shot, front sway bar bushings bad, and rear shocks. I can do all those myself, so will put off for a while. I am getting the transfer case seal done while they have it as it's leaking:
