P0455
Old Jul 8, 2022 | 03:23 AM
Prince Somorin's Avatar
2009 GL450
P0455
Whilst tootling along in traffic yesterday an alert came up saying something about fuel filler door open (it wasn't) and check engine light came on. When I got home I read the code to be P0455 (Evaporative Emission System Leak Detected - Large Leak).
I have cleared the code but haven't driven the car since to find out if it'll come back. I faintly remember the fuel filler door warning coming on back in Los Angeles.
Will an ordinary fuel filler door throw a code?
Thanks.
Old Jul 8, 2022 | 02:55 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Thanks.
Yep, in all cars. It’s not the door it’s the cap letting out back pressure either by being not fastened or having a faulty seal.
Old Jul 9, 2022 | 06:01 AM
2009 GL450
Okay, thank you Sir.
Old Jul 10, 2022 | 09:32 AM
eric_in_sd's Avatar
2007 GL450
The evap solenoid can also leak, causing a 0455. Apparently this can be caused by topping up fuel, as the fuel leaks into the solenoid and degrades the seals.
Old Jul 11, 2022 | 11:47 AM
2009 GL450
Please where is this located on the 09 GL450? Is it under the right rear wheel liner or in the engine bay?
Thanks.
Old Jul 13, 2022 | 10:35 AM
eric_in_sd's Avatar
2007 GL450
Thanks.
Right rear wheel liner. It really is not hard to get to. A bit dirty, though.
