front wipers not working
Old Aug 15, 2022 | 11:26 PM
ozz_mercedez's Avatar
2012 w164
help!gl450 2012 front wipers not working, I checked the hood switch and it works I even bypass it and nothing, I recall getting the hood open alarm and went away, wonder if the code got stuck and wipers are blocked,
Old Aug 16, 2022 | 12:22 AM
Max Blast's Avatar
NGL450 w/EORP, S550
If it work prior to your hood alarm then it could very likely be a stored and active code. If you don’t have access to an MB star system removing all battery voltage from the car for a short period should do a code reset. Nothing should persist after that until you actuate the system again.
Old Aug 16, 2022 | 06:17 AM
Miguk_Saram's Avatar
'07 GL450
DIY 101: check the fuse(s). Fuse 100, 30Amp in engine compartment, and Fuse 60, 5Amp in trunk
Old Aug 16, 2022 | 09:40 PM
2012 w164
Thanks, temoves the battey for 20 mins, checked those fuse and they are ok, but there is no voltage on them when wipers are on
I did put it in Reverse and the rear wipers go on so its not the column control
I think the hood open code still there blocking the front wipers
any other idea? or someone in the SoCal area with a good scanner who can help me
taking it to the dealer will cost at least 240 for inspection
Old Aug 17, 2022 | 01:29 PM
DarthVaderpa's Avatar
X166 GL550
If the hood is open the wipers are disabled by the controller as a safety feature so if the hood open icon is lit, then the wipers will not work.
First place to look is the hood open switch.
Old Aug 17, 2022 | 03:21 PM
2012 w164
was fuse #60 thanks for thw help!!! wipers work again
Old May 9, 2025 | 04:49 AM
twcom's Avatar
2012 GL 450. 2014 Smart Fortwo Passion
Wiped did not work this morning on 2012 gl450 will check fuses. Stalk is good rear wiper is good front washer is good. Unfortunately it is due to be raining pretty good when I get off work . May have to find something close by to park under for shelter to attempt fix.
Old May 9, 2025 | 05:52 PM
Aussiesuede's Avatar
SL500 & GL450
If you find no luck after checking the mentioned fuses, then the next step are the two relays in the fuse box in the hood compartment. The two relays will be the yellow ones nearest the drivers side. One of the relays controls on/off and the other controls the rains sensor intermittent delay. It's exceedingly rare that both will fail at the same time so just swap the relays with one another. If you wipers start working again, then you know the other relay is the culprit. A new relay will set you back about $10 bucks.
Old May 9, 2025 | 07:19 PM
twcom's Avatar
Appreciate the help. It turned out to be the #60 fuse in the luggage area fuse block. Fuse was replaced and wipers are all in order and working properly now. Here is an odd thing, while the #60 fuse was blown dash error message "Blind spot assist inoperable" displayed even though I have the Blind spot assist function off. As the light on the side mirror just bothers me so much. I turn it off and put the little round blind spot mirrors over the light area. Anyhow when the new fuse was put in the "blind spot assist inoperable" message also went away. I'll be interested to see what the connection fuse #60 has with the blind spot sensors. But this rainy day ended very well.
