rusty oil pan
Old Sep 8, 2022 | 02:31 PM
themotts's Avatar
2017 S63, 2003 SL500, 2010 S550, 2008 GL 450
rusty oil pan
Well fellas need some guidance, oil pan is in poor condition from rust ... i looked for directions for replacement and have not seen video or pdf.
any help would be great. 2008 gl450
thanks
Old Sep 8, 2022 | 03:44 PM
Max Blast's Avatar
NGL450 w/EORP, S550
thanks
On the outside or inside?
Old Sep 8, 2022 | 04:21 PM
eric_in_sd's Avatar
2007 GL450
If you want, I can look up in WIS what is the sealing method. Knowing MB, it is probably a silicone bead.
If it isn't leaking oil yet, I'd just scrub the rust, clean thoroughly, and repaint with it on the motor.
Old Sep 8, 2022 | 04:42 PM
themotts's Avatar
does not leak, i use vac to do oil changes, but was going to do a full drain and fill but drain plug area was real bad i would not turn plug.. i know rusting all the way trough is rare and yes it got a coat of paint but still would like procedure incase i want to swap before disaster . thanks
Old Sep 8, 2022 | 05:07 PM
eric_in_sd's Avatar
2007 GL450
Shoot some PB Blaster on it, soak overnight, and be careful to not strip the drain plug head. No way would I go to replace the pan because of some surface rust and a stuck drain plug. It will cost you money, be a fair amount of work, and probably leak afterward because if you're anything like me, you screw up everything you touch.
I have not drained the oil in my motor in 140k miles. Warm the engine, vacuum out the warm oil, and you're good to go. The only reason for doing the bottom side drain is if you are pressed for time, like you are a repair shop.
Old Sep 8, 2022 | 05:26 PM
Max Blast's Avatar
NGL450 w/EORP, S550
By the time you need to actually loosen that drain plug that motor will be toast anyway… Just no reason for ever having to drain the oil out of a Mercedes engine they are all designed for Topsider extraction. I wouldn’t worry about surface rust, I would worry about internal rusted for borescope or something like that revealed it in which case you got bigger problems going on.
