07 gl450 stalled on High way now dead in the water
!!!!!ATTENTION!!!!
Opened ecu to check if a anything physically happened but didn't see anything. Also took part front sam and eis and did the Same thing but could not find anything just havent checked the cgw also replaced 2 cam position sensors with pig tail and crank sense. Still has code p0335
Check for water damage on rear SAM.
In the alternative that something else was failing and the plugs have nothing to do with this I think you’ve done your due diligence with the other pieces that are suspect. In any case rule the heat range out.
There is no need to pull the alternator nor to do a bench test. Just put the car in maintenance mode on the voltage output will be right on your dash display. Do you want to get really froggy and do a load test you’ll need a MB star tool to run a diagnostics of the alternator with varying loads.
