Front bag replacement
Old Nov 24, 2022 | 07:26 PM
expl0rer's Avatar
GL550 X164
2010 550
It was about time for the front airbags to start giving me grief. One bag is done for sure and I might as well replace both. I'm thinking eventually the front struts will need to go. Not excited to tackle the struts in the cold so I'm thinking about replacing the bags temporarily. I will replace the struts with Bilstein. Do I buy the struts now, pull the bags from the new struts and replace the ageing ones on the truck? Or does Bilstein sell bags and struts separately? I can't seem to find Bilstein bags in my usual parts supplier inventories. Or is it a bad idea to do this? Trying to avoid Arnott because of the $$$ or other brands because I'm not confident in them.
Thanks in advance!
Old Nov 24, 2022 | 09:55 PM
expl0rer's Avatar
GL550 X164
I didn't think to do this earlier but I just looked at the Bilstein product catalogue and they indeed do NOT offer the air springs for the front separately. Springs and struts are one package.
Old Nov 24, 2022 | 10:18 PM
Max Blast's Avatar
NGL450 w/EORP, S550
And it’s so much easier just to swap out the struts and bag combo than fumble**** around getting a new bag onto your old strut.
You’ll need an impact driver to get the bag seated onto the struts if you do choose to do a front bagectomy. If I had non-ads o would just buy complete struts from Arnott or Bilstein and swap them out. About an hour a side.
Old Nov 25, 2022 | 01:17 AM
eric_in_sd's Avatar
2007 GL450
When you do the complete strut, you get a new (or rebuilt) shock absorber. Usually if the bag has worn out, the shock could use replacing too - its life is typically not that much more than the bag. The rear shocks last about 90k miles, while the bags typically about 60k.
If you don't have already, a propane space heater greatly alleviates the pain of working in an unheated garage.
In any event, as the Russians chuckled in a trolling video to Europe: Don't delay. Winter is coming.
Old Nov 27, 2022 | 06:01 AM
Prince Somorin's Avatar
2009 GL450
OP, please indulge me in latching on to this thread. My left front gave up about a mile home and we dragged/scraped our way home.
So I have non ADS (that much I've learnt). Am I hearing the front is actually two pieces? As in strut and bag?
Thanks.
Old Nov 27, 2022 | 07:20 AM
Max Blast's Avatar
NGL450 w/EORP, S550
Yes, the bag mounts onto the strut. You should buy a replacement unit strut and bag and just swap out. Both sides. Easy.
Old Nov 27, 2022 | 07:28 AM
eric_in_sd's Avatar
2007 GL450
Thanks.
In the future, watch out for leaking bags. They typically start leaking long before they fail. The problem is that leaky bags consume the precious lifetime of the pump, and thanks to moisture blown into the valve block, can destroy it as well.
Raise the suspension and spray soapy water on the bags. Look for bubbles or foam forming on the surface.
Old Nov 29, 2022 | 07:07 AM
texas008's Avatar
2007 GL450
Arnott whole strut assembly $950 for both front, $180 labor to replace both on my driveway by mobile mechanic (about 1.5 hour). That's what I did in 2018.
Old Nov 29, 2022 | 07:09 AM
texas008's Avatar
2007 GL450
and before that, MB dealer charged $4300 for both front strut replacement in 2014.
Old Nov 29, 2022 | 06:47 PM
Max Blast's Avatar
NGL450 w/EORP, S550
have receipt?
get new ones for free. Don’t even bother troubleshooting, swap them out for known good ones. It’s been four years almost 5 they are ready.
Old Nov 30, 2022 | 07:06 AM
texas008's Avatar
2007 GL450
Originally Posted by Max Blast
have receipt?
that's good idea. really need to save all those receipts in a folder.
Old Nov 30, 2022 | 11:26 AM
eric_in_sd's Avatar
2007 GL450
Arnott keeps records of the purchaser. Or at least they did. My experience is from when I purchased directly from them, so maybe that's how it works. You could probably register your products purchased from a third party.
Edit: Arnott no longer provides free shipping for the returns. For the struts, shipping will be so costly there is little point to the warranty.
I wonder if Arnott made that change retroactive.
Old Nov 30, 2022 | 06:30 PM
lkchris's Avatar
'10 CL550, '12 GL550
It’s my experience that he life of hydraulic shock absorbers for these vehicles is very similar to life of the rubber air springs.
I therefor think at the first sign of trouble with any spring, it’s the best idea to replace them all, front and back. Of course since struts are single units combining shock and spring, both get replaced. Recommend also at same time replacement of the (separate) shocks at rear.
This is normal wear and normal maintenance on these vehicles. It’s NOT a part failure or design problem … but it is expensive. Cost of doing business.
Old Nov 30, 2022 | 07:00 PM
EWT's Avatar
EWT
11 ML550, 95 Supra TT, 14 Audi S4
I just sent one back a couple of days ago. They didn't include a return label, although there should have been one per customer service. They emailed me one, which I used to return. I purchased directly from them many years ago, so maybe the policy has changed on newer purchases?
Old Nov 30, 2022 | 07:40 PM
eric_in_sd's Avatar
2007 GL450
Well, I think you answered the question. They did not make the change retroactive. That is nice to know. They must be itching to get you and me off their roster.
I will keep the Arnott struts around because of this return policy, but I already installed an AMK pump, selling the Arnott Chinesium replacement pump on Ebay, and have a couple of Bilstein rear bags on the shelf.
Old Nov 30, 2022 | 09:54 PM
TX07GL450's Avatar
Mercedes Benz 2007 GL450 , 2012 BMW 528i
I also got my front Arnott struts replaced under warranty about 2 months ago. One of them had started leaking after 4 years of use. Mine were bought through third party (buyautoparts.com) in December 2016. While it did involve some extra steps/hassle but I was able to get them replaced with free shipping both ways. I noticed that even though buyautoparts.com issued the labels, struts shipped from and returned to Arnot warehouses.
Old Dec 15, 2022 | 07:19 PM
expl0rer's Avatar
GL550 X164
I received Bilstein struts from Rock Auto and an indy will do the work. I don't have a garage so in the Canadian cold I'm not even entertaining the idea of any kind of mechanical work.
I'll try Arnott to see if they'd be interested in my MB ADS front struts and rear shocks. Considering I paid $200 Can shipping for the Rock Auto purchase, I'm thinking Arnott are not interested in just buying cores unless I ship them. We shall see.
Side note. I'm impressed with the Rock Auto return process. One strut was not packed properly, missing the foam cap protecting the airline valve and the three threaded studs at the top. My guess is customs was careless in repacking it. The box had been opened, it was obvious. They shipped a replacement next day and paid for the return. I continue to be a fan of theirs.
Second side note. Buying from Rock Auto, I saved half compared to what the Canadian Bilstein distributor charges. Insane!
Old Dec 21, 2022 | 12:11 PM
expl0rer's Avatar
GL550 X164
Front struts replaced. Now that the beast is on 2 year old rear bags and shocks plus new front struts I can tell why replacing these all at once when buying a GL is a good idea, if their age is unknown. The car is as tight as I expected it to be from the beginning, but it never really was tight enough. It was a little sloppy in the front and if I can tell the difference in the ride, those struts were worn down well enough. Now the sleigh is ready for adventures again.
Old Dec 21, 2022 | 01:19 PM
Twinreds's Avatar
E 63 // Porsche 930 // Porsche 993
I just posted on the front bags. I think that MB screwed up on a design flaw that is conveniently costing us lots of money on front bag replacements. I just found out that the hood cowl valve drains right on the bag assembly and rusts it prematurely
Old Dec 21, 2022 | 01:58 PM
expl0rer's Avatar
GL550 X164
Mine were equally dirty. I can't say that one side had more wear than the other, or had been exposed to more elements or stress or corrosion, visually. Any design flaw that may exist would be part amd parcel with the numerous others Mercedes has done nothing about on the x164. Unfortunately for us owners who have these old classic specimens.
Old Dec 22, 2022 | 08:51 AM
Twinreds's Avatar
Still an awesome tank, but these little stupid flaws....
