to replace front lower control arms
The upper arms seems fine, and the struts were replaced 11k miles ago at 100k miles.
While replacing those two CAs, seems its a good opportunity to get the following parts replaced all together:
both front brake rotors (noticeable lips on them)
both front lower ball joints (original never replaced)
stabilizer bar bushings (4) and links (2) (original never replaced)
various nuts as listed in FCP's front suspension service kit.
wonder if there is any other parts that might need attention while replacing the CA's?
thanks a lot,
Yes the tool is called Mercedes Ball Joint Socket 4-Lug CTA Manufacturing 1082.
I pretty much did the same you did and did not replace any of the nuts. They are lock nuts that should be replaced, but most of them have pretty high tightening torques. I haven't detected any movement in them. I'd only replace them if I wasn't going to look under my car again.
Lower ball joints are optional. They are pressed into the knuckle. You need to remove the axle from the knuckle to get them out. I had issues with axle in the knuckle, so couldn't replace one side. However I'd replace them, as your 90% there.
I'd regret not doing the tie rods. It would have been bugger all extra work at the time. They didn't need changing, but then I'd know I'd be good pretty much for my ownership life.
Just received the lower control arms, seems that they are made of cast iron and they are massive and so heavy, maybe 40lb each.
