Radio keeps rebooting every 10 minutes or so.....
Common problem ?
Any fix ?
thanks
Its actually been doing it for a coupe of years! only just thought to post about it here,lol
Have never used the CD/DVD slot only the radio and usually bluetooth the connection from my phone.
so you have no CDs or DVDs and the command display unit reboots every so often with the Mercedes logo as if it initially powered up after engine start... this happened to me after a few years of the radio just cutting out and turning off after forty so minutes of playing ...I have not had any back up camera or a correctable clock on the gauge clusters for over a year....
there is a supposedly a battery saver relay I am going to look for,
a bunch of optical connections to subcomponents such as the amplifier under the driver seat, the sirius sat radio module under behind that under the second row with the telephone interface next to that and the display LCD and clock are also can bussed into the radio (not sure on the last two) ...
and I am thinking I shall try to reassemble my display but try to run it without the Toshiba hard drive in it ( I hope this is just for navigation and MP3s ) , crossing my fingers this is a scenario similar to a dead battery in a laptop that won't turn on until you remove the dead battery.
