Partial Airmatic Conversion
So, am I able to keep the current setup by making sure that front height sensors are set to constant high position? Does the system then function normally, so that if rear was low, it would inflate it and cut off the compressor when rear is up?
I really would like to go back to air also in front, but don't have a good place to work on car right now so I was thinking about this as a temporary solution.
WIll this work?
It’ll handle like a pig, it’ll be dangerous to drive because it will not have a functioning ESP system, the ride will be incredibly harsh, upfront and mushy in the back, depending upon the age of the rear airbags. I wouldn’t drive this vehicle, nor want to be next to one in traffic Until you have sorted out two new rear bags and two new front struts but then again it’s a diesel, so why spend any money on it it will eat your lunch with engine issues shortly anyway.
I generally do not recommend them as they degrade the supple ride that this car supposed to have.
I have my doubts the ESP system is as sophisticated as you think, so sophisticated as to care about the details of the spring rate. It basically just looks at speed, yaw, roll and wheelslip. Roll is affected by spring stiffness, but much more so by swaybars. Suspension geometry strongly affects cornering stability, but that should not be affected by the struts or springs.
Air springs are excellent as far as ride is concerned, though. They have a 1/X spring rate, meaning small bumps are more easily absorbed than large, while coil springs are linear, with the force directly proportional to displacement.
Obviously I have bunch of fault codes for suspension currently, but at least I am able to move the car and it doesn't sit like a frog any more.
There must have been a reason for previous owner to convert to springs. Driver beware.
Good luck.
Removing those coilovers was not fun. Maybe I am not very good with spring compression tools but to get that last missing centimeter compressed was a pain, but managed affter all without removing the hub. Installing air stuts was a breeze and really don't get why anyone would want to get rid of them. Such a simple system.
Total cost 250 usd : used compressor/solenoid valves from ebay and new air struts from local facebook sellers.
Air springs do two things steel coils don't: Wear out, and fail catastrophically. They take maintenance and attention, while steel springs only fail if you do something weird like welding on them.
Though the ability to raise the suspension 3" is nifty.
I installed mine last week and couldn't load 4 people and camping gear in it without it sagging to the fenders.
I don't know if they gave me the wrong spring rate or not but I'm not happy.
