Transmission gasket leak after new seal
Old Mar 24, 2023 | 04:40 PM
darens67's Avatar
x164
I am in the middle of a transmission flush on my X164. I dropped pan, emptied torque convertor. replaced filter, but new transmission gasket seal and when i started pumping first quart of transmission fluid it was leaking in middle bolt passenger side of the pan. I tightened it. get pumping and leaked again and again. I believe I did everything right and all looked good. All bolts were tight.
I assume I need to drop pan again and take a peak at the gasket. (Maybe I bent pan- I dont think I did). Maybe I overtightened it - and crimped gasket. Totally frustrated (but I only used 1 quart so not that bad).
What do you all think
Old Mar 24, 2023 | 06:31 PM
Diamond Dave's Avatar
GL320 CDI
Correct. Since you already tried tightening the offending bolt, the only remedy at this point is dropping the pan and verifying the gasket. I suppose you could start by loosening all the bolts and re-attempting the torque pattern before removing the pan.
Old Mar 27, 2023 | 07:23 PM
darens67's Avatar
x164
ok. this was the problem. one of the bolt pan holders that hold up the pan did not catch the pan. there are 6 pan holders that are affixed to all 6 transmission pan bolts. One did not catch the pan and it leaked. I warped gasket so I purchased another one for $22 at Mercedes. Transmission fluid flush and torque converter not hard. If you can do an oil change just a tad harder.
