Bulbs for DLR
Old Apr 23, 2023 | 01:42 PM
Elbeau's Avatar
Mercedes gl450
Bulbs for DLR
My 2011 GL450 has the 4 round lights in the bumper. 2 fog lights (the inner lights) and 2 DRLs. What bulbs do the DRLs take? Also, has anyone used LED bulbs in the DRL that did not result in codes? Thanks
Old Apr 25, 2023 | 01:21 PM
Elbeau's Avatar
Mercedes gl450
Originally Posted by Elbeau
My 2011 GL450 has the 4 round lights in the bumper. 2 fog lights (the inner lights) and 2 DRLs. The bulbs are PSX26W bulbs. Has anyone used LED bulbs in the DRL that did not result in codes? Thanks
DRL bulb for 2011 GL450.
Old Apr 25, 2023 | 03:10 PM
Diamond Dave's Avatar
GL320 CDI
Interested in solutions here.
I made the mistake of replacing all my headlight DRL's with LED and the blink a few times before turning off and throwing codes. I replaced my reverse lights with LED and they work - but also throw codes.
Old Apr 25, 2023 | 07:46 PM
Elbeau's Avatar
Mercedes gl450
LEDs for DRL, etc.
well, I changed my parking lamps to LEDs and got the flashing, then going out. Tried a different set and they work fine. Will be replacing the DRLs tomorrow. I'll see how that goes. I order a few different ones from Amazon - ones ppl have used without trouble on the benz or ones not reporting such issues. I try them and return the ones that code, flash and/or don't look good and keep the one that works/looks best. I'll post the ones I've used without problem so far later.
These are the parking light LEDs I used. No problems, no codes. Much brighter.
Parking lights replacement - no codes, work great.
Old Aug 21, 2023 | 12:45 PM
Elbeau's Avatar
Mercedes gl450
These are the ones I am using in my DRLs and outside turn signals/parking lights. No errors, no codes. I did get a bulb out message on one DRL when I first installed them. I turned the car off and restarted and no problems since. Same thing happened with a headlight LED, too..
Old Aug 22, 2023 | 08:36 PM
lkchris's Avatar
'10 CL550, '12 GL550
Bulbs are listed in owners manual, no?
Old Aug 22, 2023 | 09:46 PM
Elbeau's Avatar
Mercedes gl450
Yes. Some of them and they list the bulb receptical type, not specific brands and not LED or other substitute bulbs. In addition, for some it simply says to have the dealership replace them. And that is only because they are very difficult to access.
