AC Different Temperatures
Old Aug 30, 2023 | 11:53 PM
91stealthes's Avatar
2012 GL350
My wife informed me a few months ago that the AC wasn't blowing cold. Truck had to go into the dealer for another issue, so I had them investigate. They said it needed an evac and charge, and also did a leak test. AC wasn't ice cold when I got it back, but it was also 90+ degrees, so didn't think too much of it. I've now noticed that the passenger side blows cold, driver side blows warm, and rear blows cool. Any thoughts?
Old Aug 31, 2023 | 03:43 PM
eric_in_sd's Avatar
2007 GL450
I am not familiar with the plumbing, but I bet there are control valves for the coolant flow to heat the cabin, and one of them is stuck open.
Old Sep 1, 2023 | 10:27 AM
BamaGLE450's Avatar
2023 GLE450
mine did this too. There is a software reboot you can do yourself by pushing a combo of buttons on the dash. After I reset mine it works much better but still doesn’t seem to blast out cold air sometimes unless I run down the temp. At dealer now to have this checked because I have bigger issues with transmission on a new GLE450
Old Sep 3, 2023 | 03:53 PM
DennisG01's Avatar
'08 GL 320 CDI
Same thing happened to mine - when the system is low on coolant, it causes that temp differential - passenger side cooler than the driver's. My Indy said this isn't all that uncommon with older systems. There may be a small/slow leak.
