Transmission lag when shifting in/out of reverse
Old Nov 18, 2023 | 09:06 AM
Elbeau's Avatar
Mercedes gl450
There is a second or so lag before power is engaged after I shift into or out of reverse. I always fully stop before making such shifts. Is this a "feature" or what?
(I remember this happening on my new Benz's in the 90s, regardless of model).
No codes, No other shifting anomalies. Trans recently serviced, road tested by mechanic. Did this since I've had it.
Old Nov 29, 2023 | 02:02 AM
kimolas's Avatar
GL450 X164
No clue if it's healthy behavior but mine is identical.
Old Dec 15, 2023 | 12:37 PM
W205C43PFL's Avatar
If it has been doing it since you had it when purchased new, then it might be normal. Unless you mean since you had it when purchased used?
Old Dec 15, 2023 | 12:55 PM
kimolas's Avatar
GL450 X164
purchased at 135k miles and has been doing this since then. I've seen transmission fluid service videos on YouTube where the STAR system reports a similar lag between the requested and the actual gear as well.
Old Dec 15, 2023 | 01:11 PM
Elbeau's Avatar
Mercedes gl450
Mine's been doing it since I purchased it used. But I've experienced the same thing on new ones bought in the late 90's, early to mid 2000's. Had the trans serviced recently and no problems were found. I also recently changed both the main and aux batteries, which had no impact. I suspect it's a designed-in thing to prevent damage by those who shift from reverse to drive without fully stopping. (Although, personally, I feel they, not I, should suffer for their actions).
Old Dec 15, 2023 | 01:19 PM
W205C43PFL's Avatar
Likely it is normal then : ) Enjoy your cars.
