Trying to find a power steering reservoir cap for my GL450...
Old Mar 3, 2024 | 10:14 PM
majorchamp's Avatar
2011 GL450 VIN: 4JGBF7BE8BA706134
So been searching far and wide. Kind of cracked part of the cap...it isn't exposing anything inside the reservoir but I'd like to just replace the cap now.
I can find the cap for all types of vehicles...but I cannot for the GL450 (2011). Is this a part that is common on other models of Mercedes and would work on the GL450...but online databases simply view it as 'not a match'?
If so...what other model could I select that would make it a match? I don't want to replace the entire reservoir for a cap...
Old Mar 3, 2024 | 10:16 PM
Max Blast's Avatar
NGL450 w/EORP, S550
$70 for a new reservoir, use that cap.
Depending on how old your reservoir is it's time to change it anyway - there is a filter in there that clogs over time.
Or find a cap in a junkyard. Common to a lot of MB from the 00s.
Old Mar 3, 2024 | 11:22 PM
eric_in_sd's Avatar
2007 GL450
Agreed. Changing the reservoir is not a very difficult service. Just make sure you use a new D-ring, and make sure you install at the right point.
Not to inflict a cascading series of repairs, but it would not be a bad idea to replace the pump and low pressure hoses at the same time if they are aged.
Old Mar 5, 2024 | 05:00 PM
lkchris's Avatar
'10 CL550, '12 GL550
Also, verify you don't have a leak at the oil cooler-to filter canister interface ... just a new gasket required. This leak is common and you have to take the power steering reservoir off to fix it. There is a power steering bleeding procedure to perform when replacing the reservoir which you can likely find by searching X164 or W164 forums.
Old Apr 18, 2024 | 07:54 AM
texas008's Avatar
2007 GL450
The PS reservoir is on sale for $20 at FCP euro now.
