Is there any way to change the seal without removing Rack n pinion
Thank you for taking time to answer the thread.
So v6 gl320 will work for sure and the ML500 and R350 I’ll need to look more into. Reason I asked is every day these cars sit in yard they are stripped of everything worth anything.
Tomorrow ML might have it and GL will not.
If you happen to know,is it possible to pop a seal into mine where tie rod slides in without removing whole rack?
Rack seals and bellows are sold. Given the difficulty of replacing the rack (you have to drop the differential), I am inclined to try replacing the seals. However, if the bellows have failed, it seems likely the shaft underneath is worn from dirt, etc.
