power steering pump & hoses replacement question
bought the remanufactured Bosch from FCP euro.
I've replaced the power steering reservoir before, so this task seems manageable.
Question is
1. is it a good idea to replace the two power steering hoses?
2. wonder if there is a write up or youtube video on how to replace those two hoses, I had an impression that one of the hose end is pretty hard to reach.
thanks a lot,
None benefit particularly from being changed along with the power steering pump. Of course it saves some labor, but I like to be miserly and to live dangerously, so I only changed them on an as-needed basis.
Remember, the low pressure power steering lines can leak onto and degrade the lower heater hose, so it is important to not ignore leaks in this area. It would be so much better if the solid metal section of the lower heater hose extended past where the low pressure power steering hose connects.
