2009 GL450-Secondary Air Pump
Old Apr 23, 2024 | 10:44 AM
bestlsm3786's Avatar
Mercedes Benz GL450
Hello, In my 2009 GL450. Replaced Secondary Air Pump and cleared code P0410, After 4 days Check Engine Sign popped up, what to do to rid of the sign Check Engine?p3 times. I am still getting checked Engine signs, Do you have any ideas, on what to do? If you can fix the problem, I would invite you to fix the problem. in the 2009 Mercedes GL450.
Old Apr 23, 2024 | 09:43 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Buy a code reader
read what code triggered the check engine light
clear code
observe if it reappears.
Old Apr 23, 2024 | 10:52 PM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
Definitely worth watching for P0410
Here is a decent video with a chart for secondary air issues . This will help you understand the secondary air and how to troubleshoot .. read your codes.
