2008 GL320 aircon valve replaced. Do I need to do adaptation?
About 9 months ago I replaced the compressor control valve on my GL320 and since then it’s all good for short trips but after about 45 minutes the air volume through the vents gradually decreases and comes to be gradually useless
if I catch it early enough and put the heater on full heat and full fan for a few minutes then it seems to improve
if I run full fan it doesn’t seem to do it
I thought the evaporator was freezing but there seems to be water running out of under the car as normal
the problem has only occurred after I changed the compressor control valve. Is there something I should have scanned in?
