oil leaking
Cleaned it up, fresh filter o rings, and oil.
Now 5 years later and multiple oil changes later everyone preformed myself. The oil leak is back. Currently trying the 2nd new cap and filter and
after minute it starts seeping out at a random location localized spot of cap at housing and cap lip. Several R&R just leak moves to around the lip.
Thoughts on this random leak? Replacing housing, possible blocking within cooler???, open to any ideas.
I never got true proper info on the failure other than "internal check valve failure, oil & coolant mix & leak externally". This was from a Benz indy shop owner who is a master tech and former dealership shop foreman. I wonder if your issue is pressure related?
The assembly has had at least 1 if not 2 part number revisions. I understand this is sometimes due to Benz sourcing a different company to manufacture a part and not always a mechanical revision on said part, but again I need more info on that myself. Just a consideration.
Check the filler assembly is straight on the neck where the filter attaches- they can bend out of shape. Also, which filter set are you using? I've always used MAN and never had a problem but others might have a different spec on the O ring?
It has a specific receiver groove but it also *could* theorhetically seat behind that groove too. You're seating the filter all the way so the line disappears right?
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Literally every other seal, gasket, or o ring that wasn't Genuine (besides 1 Elring trans pan gasket) has given me instant issue like your situation. Especially an o ring w/ a Bosch crank position sensor. Literally twice the size of the Genuine one I sourced locally and the sensor wouldn't even fully seat.
https://www.pelicanparts.com/techart...Oil_Change.htm
OP can you confirm that the big O-ring is seated correctly?
I have used to different caps several sets of rings and as I have stated it is a 1/4 inch wide slow stream. If I change caps and or rings it just moves around somewhere else
just under lip.
W
Has any one experienced blockage in the oil cooler?
Oil cooler has a ball check valve or something in it yeah but thats not why it's leaking, it's not meant to be user serviceable and I strongly recommend changing the entire oil cooler. The URO part suffices 99% of the time.
I think you have a cracked oil filter housing.. aluminum has a finite lifespan for stress.
In a 1063K miles you've only changed the o-rigns twice????
If you had a blockage somewhere, causing built-up pressure, you'd have other issues. But it sure is easy to check - DO you have pressure?
How closely have you inspected the housing?
Are you tightening the cap all the way down?
