Wheel hub replacement
Old Feb 9, 2025 | 12:02 PM
mjanasik's Avatar
GL320
I have some stripped threads on the rear driver's wheel hub on an '07 GL320. I am probably going to replace the hub as I don't want to risk using a helicoil/time-sert or similar repair. I watched a few videos of the closest thing I could find which were bearing replacements and it looks like quite a bit of removal is necessary. Wondering if there is a simpler solution/tools to just remove and replace the hub on vehicle.
Old Feb 9, 2025 | 03:25 PM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
hub
Hub is pressed into the rear and front bearings. No easy replacement… watch some more videos and replace rear bearings while you are at it.
