GL320 codes 2094-1 3052-4 2645-1 2600-2 2602-2
Old Feb 15, 2025 | 04:51 AM
hamazz's Avatar
GL320 ML 350
2007 X164 GL320 throwing the following codes
2094-1
3052-4
2645-1
2600-2
2602-2
The car drives fine and no issues with limp mode or acceleration, swirl motor has a resistor mod on it,
Anyone have any ideas what could be the cause of these code?
If i try to clear them, they come up again within a few minutes the next time the engine is started
Thanks in advance
Hamazz
Old Feb 15, 2025 | 01:49 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Try having the car scanned again, and run a short test with the proper Mercedes X entry tool.
The short test will tell you which module is providing all these codes none of which I’m recognizing.
Old Feb 16, 2025 | 11:46 AM
hamazz's Avatar
GL320 ML 350
I dont have access to a xentry as currently abroad and no local garages that i know that have them,
i used my autolink scanner and it came up with the following codes
p2a00
p0101
p1101
p1102
p1111
p1112
When i clear the codes, they go away then come back after turning the car on and letting it run for a while.
Hamazaz
Old Feb 23, 2025 | 01:59 PM
Diamond Dave's Avatar
GL320 CDI
Generic code readers won't read the real Mercedes codes. You need a tool that will, like an iCarsoft MBii for ~$150
