GL450 underpowered?
Old May 28, 2025 | 04:20 PM
735's Avatar
735
2006 S350L
Honestly, I'd avoid "launching" an X164 considering how expensive it will be to deal with either 7G, Transfer case, or front diff.. (my opinion.. I really don't feel these are "launching" style vehicles tbh..)
Old May 28, 2025 | 04:30 PM
01blackhawk's Avatar
2005 ML500, 2011 E350 4M, 2012 GL550
Talking
Add that the engine mounts, tranny mount, drive shaft flex discs etc etc... I absolutely agree with that approach, after all, these are not sports cars, treating a luxury SUV like a sports car would have some stiff financial consequences for sure.
Old May 28, 2025 | 04:33 PM
735's Avatar
735
2006 S350L
I recently bought one of these a couple of months ago and replacing all of what you just wrote & the conductor plate, batteries, airmatic leaking bags, bla bla bla, has cost >6K and climbing.
The last thing I can imagine myself doing is launching it. Yes it's fast no doubt, but.. why.. It just feels like *SO MUCH* is being stressed/torqued when you hit the gas hard on these, I'd try to stay away from the MB parts desk by being soft on this one.. This isn't the type of vehicle for that type of driving..
Old May 28, 2025 | 05:48 PM
W205C43PFL's Avatar
The motor mounts is especially a pain especially for 4MATIC vehicles.
Old May 28, 2025 | 05:49 PM
W205C43PFL's Avatar
Yes lots of things work in conjunction to achieve that.
Old May 28, 2025 | 05:50 PM
735's Avatar
735
2006 S350L
One thing is for sure, after buying the GL (X164) I am happy I didn't buy a 4MATIC W221
I'd have *DESTROYED* my wallet with that..
I can totally imagine what would have happened to me ..
RWD forever.
X164 = children transporter
W221 = personal transporter
Old May 28, 2025 | 05:51 PM
  #32
W205C43PFL's Avatar
I am curious what OP really wants to achieve though.
Old May 28, 2025 | 05:52 PM
  #33
W205C43PFL's Avatar
RWD forever.
Yup, 4MATIC there is the addition of a transfer case and front differential. There are also particular requirements for the tires and tread level as it might affect the drivetrain.
Old May 28, 2025 | 05:53 PM
  #34
W205C43PFL's Avatar
Thats possible, also flaps in the intake manifold, I`d check the codes also a visual check on the lever. Its doesn`t always give a code, depending on what position it got broken and stuck.
Driven both 450 and 550 on the 164 platform, I can tell 550 is a bit more peppy at the launch but 450 is no slouch either, also when you are down to sea level you will have a noticeable difference, they both feel much more alive. Being in CO sucks, especially going to higher altitude.
For sure, really curious and look forward to hearing an update from OP.
Old May 28, 2025 | 08:02 PM
  #35
Max Blast's Avatar
NGL450 w/EORP, S550
It’s either Baller cred or something terribly wrong with their transmission.
Old May 28, 2025 | 09:44 PM
  #36
W205C43PFL's Avatar
Will need OP to update us to be sure.
Old May 29, 2025 | 08:05 PM
  #37
lkchris's Avatar
'10 CL550, '12 GL550
My 2007 diesel isn't underpowered either.
Old May 29, 2025 | 09:44 PM
  #38
Max Blast's Avatar
NGL450 w/EORP, S550
Eeeeh…. All right I won’t disagree with you.
….except for when it goes into limp mode
Old May 29, 2025 | 09:45 PM
  #39
Max Blast's Avatar
NGL450 w/EORP, S550
I think Opie has left the chat
Old May 29, 2025 | 10:24 PM
  #40
W205C43PFL's Avatar
Yuppers.
Old Jan 9, 2026 | 11:57 PM
  #41
gl450BENZ's Avatar
2010 Mercedes Benz GL450 4MATIC
GL450
to be honest was just trying to test out the power, maybe have some “baller cred” as the other guy stated. There is nothing wrong with the car, I just for some reason dont like when the car feels stressed when flooring it. Especially since its a mercedes.
Old Jan 12, 2026 | 09:28 PM
  #42
lkchris's Avatar
Probably if you had a manual transmission, a 7-speed would be considered a performance item.
The Mercedes automatic has seven speeds for fuel economy reasons. The first couple gears are pretty short and you won't wind out to any particular speed.
You're looking for something the car wasn't designed to be. The top speed your GL450 can achieve proves it's not underpowered, as aerodynamic drag increases with the square of speed and it will require plenty power to pull the top speed your vehicle can achieve.
The next generation GL, the X166, has an AMG version. AMG engine, AMG tuned transmission. Your fantasy vehicle, perhaps?
Old Jan 13, 2026 | 10:58 AM
  #43
Elbeau's Avatar
Mercedes gl450
Originally Posted by gl450BENZ
Hello guys,
I have a 2010 GL450. It’s a 4.7l v8 with 335 hp and 339 pound feet of torque. I always felt the car was underpowered for a v8 benz. For instance when I floor it from a stop the RPM shoot up before they shift and the engine sounds stressed. When its in there 3rd gear around 30mph then it feels better when I floor it, but do you guys think this SUV is underpowered? Does making the RPM’s shoot up to 4-5k from a stop bad for the engine? I often like flooring it.
"For a Benz" is like saying "for a vehicle." Different Benz's are made for different purposes. The GL450 isn't made for speed. It's heavy and huge. It's made to transport 7 people and tow. That said, it has plenty of power, just not off the line because it isn't made for that. Nonetheless, with just a little more than typical pressure on the pedal, I easily leave other cars behind starting from a light. Merging onto the highway, I'm usually at highway speed before merging in. Don't stomp on the gas, just give it pressure and the GL450 moves.
Old Jan 13, 2026 | 11:09 AM
  #44
chassis's Avatar
2017 GLE350 4MATIC
Have you considered dumping this slow boat of a vehicle and buying something that meets your expectations?
Old Jan 13, 2026 | 07:26 PM
  #45
Sallad's Avatar
Veteran: Army
Veteran: Canadian Forces
08 GL320 CDI
I understand but is flooring it bad for the engine, lets say I am at a stop light and need to merge over and I floor it. It goes up to 5k rpm. Is that bad?
Yes, it puts extra stress on the entire system. Fuel pressures rise to pretty much max the system can deliver, coolant pressures shoot straight up because of the increase in RPMs, everything is “asked” to deliver its full output right off the start.
Now if the vehicle is only a few years old, this isn’t so much of an issue, but as it ages, seals, hoses, fittings, clamps, etc., all loose their original integrity and fail. Could mean a coolant hose that has been fine at lower rpm’s, will now split open when you “floor it”.
The whole “Italian Tune Up” (by revving the **** out of an engine) is 1980s thinking. You can’t flow more fuel over the valves and blow out carbon on a modern engine. Just the increase in airflow (by revving it) is not enough to do anything for carbon. Even soaking an engine doesn’t remove all the carbon, you think a few redline pulls would do it??
Bottom line, these are big family SUVs, they are not going to be fast, they are going to be comfortable and looking good doing it. My diesel has lots of jamb for a big SUV.
