Tailgate couldnot close with push button in some cases
Old Aug 22, 2025 | 11:19 AM
nvhoang56123's Avatar
GL350
Hi,
It's a GL350 2011. I'm facing some issue with it after the rear nozzle broken and have some leak. What I test so far
Open/Close with fob: works
Open with driver button works, Close with driver button does "not" work
Open with rear door latch: work; close with push button work when vehicle in locked state
Issue that needed your advices
- WHen I press push button to close liftgate when car in unlocked, It attemps to close in 1s, then open back. In this case, I long press the push buttons and it closes successfully.
- Same behavior when I open the liftgate and want to stop at a specific height, it seems stop for 1s then open with max heigh
I do a scan and have 2 code, 98A511 and 98A52A
What I need to do? should replace the push button will fix all the issue?
Much appreciated
Old Sep 2, 2025 | 10:10 AM
wickede55's Avatar
08 gl550
I’m having similar issues also
