2011 GL350 - X164 - Refrigerant Line Routing
Old Jan 22, 2026 | 11:17 AM
Koziol's Avatar
2011 GL350
Hello Friends,
If any of you has access and can share 2011 GL350 refrigerant line routing, I would really appreciate help. Having A/C leak issues. 150psi test drop to 100psi overnight - so far not finding leaks with soap. I believe I put dye in the system 2 years ago, but also can't find visible spots. It's been over a year since I had refrigerant in the system, so it might be just washed out.
If no help, I might just add dye and charge with refrigerant again and try to locate it after few day. Unless it's evaporator (would explain why I'm not seeing anything), which would also suck.
Old Jan 22, 2026 | 07:58 PM
Sallad's Avatar
Veteran: Army
Veteran: Canadian Forces
08 GL320 CDI
Originally Posted by Koziol
It's been over a year since I had refrigerant in the system.
Unfortunately, once the system looses its pressure, that can allow moisture to enter the AC system and destroys pretty much everything with rust. (compressor, drier, evaporator, etc.)
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
