I finally picked up my GL550
Old Nov 30, 2012 | 12:47 PM
firstgl's Avatar
Its here with surround camera and easy entry second row. So far it is great, amazing handling with active curve system. The only disappointment so far is the absence of the third row roof cover. Ordered 9-21; Built 11-14; Delivered 11-27
Attached Thumbnails I finally picked up my GL550-photo1.jpg   I finally picked up my GL550-photo2.jpg   I finally picked up my GL550-photo3.jpg
Old Nov 30, 2012 | 01:22 PM
JimBarnhart's Avatar
2015 Ram 2500, former 2013 GL350, 2007 GL450
Awesome, congratulations! The wait is over. Enjoy the ride.
I'm taking my first extended trip this weekend in mine. Should put about 600 miles on this weekend. With my diesel that's a tank of gas. I'm so looking forward to it.
Old Nov 30, 2012 | 01:53 PM
Mbenz260e's Avatar
2022 E450 Prior:2021 S580 2012 E350BT, 2013 GL350BT, 2009 ML320BT, 2006 E320CDI, 1987 260E
Nice ride congrats!
Still perplexed I wasn't able to order 360 camera in October...
Old Nov 30, 2012 | 02:20 PM
luv2sleep's Avatar
'15 GL450
Niiiiiiice!!!
I can't help noticing it but the new GL's facia with a big mouth looks it's eager to hand out BJs. Seriously though, congrats on a nice looking SUV.
Old Nov 30, 2012 | 04:21 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
Can you take pictures of the rear side sunshades (option 297) and the panoramic roof over the third row for me please?
Thanks. Dude- looks like you got almost every option. Awesome!
Old Nov 30, 2012 | 10:53 PM
South Ocean1's Avatar
2020 Porsche Taycan Turbo, 2020 GLC 63, 2014 Audi S6, 2014 GL63; past 2019 M5 and 2011 E63
FirstGl
Your new GL looks great! Congrats.
How does the power second row work? Is it only power down but not up?
And have you made any decision about addressing the lack of sun shade in the third row? Given the low sun in the winter, you probably have some time to figure that one out. I'm thinking a ceramic window tint may work best.
Kind regards
Old Dec 1, 2012 | 11:47 AM
firstgl's Avatar
here you go!
Attached Thumbnails I finally picked up my GL550-photo4.jpg   I finally picked up my GL550-photo5.jpg   I finally picked up my GL550-photo6.jpg   I finally picked up my GL550-photo7.jpg
Old Dec 1, 2012 | 11:58 AM
firstgl's Avatar
Originally Posted by South Ocean1
FirstGl
Kind regards
Not yet but any suggestion is welcomed..
Old Dec 1, 2012 | 01:17 PM
Thanks for those detailed pictures. It now looks like that rear side sunshade is much easier to retrofit into a car that doesn't have it than compared to the past where it's in the door panel itself.
BTW how does the 360 camera work? Can you explain the system a little bit and how to activate the front or side cameras?
Old Dec 1, 2012 | 01:58 PM
firstgl's Avatar
Easiest way is the copy the explanation from the operating manual, which i can send you if interested.
The 360° camera is a system consisting of
four cameras.
The system analyzes images from the
following cameras:Rear view camera, Front camera and Two cameras in the exterior rear view mirrors
The cameras capture the immediate surroundings of the vehicle. The system
supports you, e.g. when parking or if vision is restricted at an exit.
The 360° camera images can be shown in full screen mode or in seven different split-screen views on the COMAND display. A split-screen view also includes a top view of the vehicle. This view is calculated from the data supplied by the installed cameras (virtual camera).
The 7 split-screen views are:
1top view and picture from the rear view camera (130° viewing angle)
2top view and picture from the front camera (without displaying the maximum steering wheel angle)
3top view and enlarged rear view Rtop view and enlarged front view
4top view and trailer view (vehicles with trailer tow hitch)
5top view and pictures from the rearward facing mirror cameras (rear wheel view)
6top view and pictures from the forward facing mirror cameras (front wheel view)
7 The top view and trailer view are available for vehicles equipped with a trailer tow hitch.
When the function is active and you shift the transmission from position D or R to N, you see the previous view in the COMAND display. The dynamic guidelines are hidden. When you change between transmission positions D and R, you see the previously selected front or rear view.
Old Dec 1, 2012 | 02:45 PM
X166's Avatar
2013 GL550
How's the tension on the rear window shades? Also, have you noticed a lot of sun getting in at the top of the window, where there is a gap between the drawn shade and the top of the glass? How's the fit and finish of the unit? Finally, when the shade is drawn, does the door lock pin disrupt it when it goes up and down?
Sorry for all the questions! Finalizing my order and your car is by far the most optioned on the boards! Thanks!
Old Dec 1, 2012 | 08:10 PM
Do you find the camera intuitive to use? Is there any easy way to get the front camera on/ is it wide enough of an angle to see both sides of the street when pulling out from a tight spot?
Old Dec 2, 2012 | 06:51 AM
Tomshop's Avatar
‘23 Rivian R1S, ‘22 Maybach S, ‘24 RR Autobiography, ‘22 Tesla X, & ‘9
It seems like the lack of a shade for the third row is a real miss. I wonder when they will fix the issue. Also, the rear sunshades really looks aftermarket. Surprising given the quality that the one in the S class has.
Old Dec 2, 2012 | 11:41 AM
dave_550's Avatar
GL550
Did you get the easy entry on 2nd row? I ordered it and was told it slipped to 2014
Old Dec 2, 2012 | 12:44 PM
firstgl's Avatar
tension, fit and finish good, lock pin doesnt disrupt, i havent used yet to notice sun through the upper gap.
Old Dec 2, 2012 | 12:47 PM
firstgl's Avatar
camera is intuitive and you can get to it easily by pressing SYS button or by assigning programable button to it.
it is wide angle, will try both sides of the street view and see if it is adequate
Old Dec 2, 2012 | 12:48 PM
firstgl's Avatar
i did as well as surround camera
Old Dec 2, 2012 | 12:52 PM
X166's Avatar
2013 GL550
@firstgl--Thanks for the reply / info. Much appreciated.
Old Dec 2, 2012 | 02:30 PM
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Thanks for the info on the camera system..... I have it ordered for my 450 and was wondering how "simple" it is to use the system....from reading the info you posted, I would assume it will take some getting used to!
Old Dec 5, 2012 | 09:50 AM
jbondox's Avatar
beater with a heater
anyone here from Ohio? Specifically Northern Ohio?
Old Dec 14, 2012 | 11:41 AM
MAD GL63's Avatar
GL63 AMG
Originally Posted by firstgl
here you go!
Curious about the rear shades... below is an excerpt from the MB home page, fasination section for GL.
Roller blinds for rear side windows [3]
The roller blind on the rear window can be electrically extended to give protection against the sun’s rays. It’s integrated into the parcel shelf in such a way as to be almost invisible; and because the film used in the blind is perforated, there is almost no restriction on the driver’s rear vision.
The rear shade is standard on the GL63 but not sure I was expecting the roller blind you have.... are there two types or have I misinturpreted the above discription?
Either way beuatiful SUV, counting the days 'til I get my own!
Old Dec 14, 2012 | 12:49 PM
That seems like a typo to me. The way the description reads, it's describing the rear shade for the back windshield on sedan models:
The W221 S Class also has optional power side window shades.
Anyways, on the GL, the shade for the first and second row pano roof are power operated. The 2nd row side shades are manual operation.
Old Dec 14, 2012 | 03:57 PM
cookstar's Avatar
2005 ML350, 2008 GL320, 2013 Gl350
The shades only come on the second row windows and are manual, I have it ordered on mine, there is about an inch gap left open on the top so it does not cover the window up entirely but it is a bonus since you get the tinted windows and the shade.
I have called MB Canada on 3 occasions to have them fix things about the Gl on the website. They also had eco start/stop as standard equipment but this is non existent in 2013 MY
