9 Speed transmission a real possibility for 2014-2015
2005 ML350, 2008 GL320, 2013 Gl350
Been reading around the net since 2010 that MB is working on a 9 speed that will debut in 2014 or 2015 on the S class and C class, another article posted this week seems to sort of confirm this as well, looks like MB is catching up.
http://www.motorauthority.com/news/1...lass-spy-shots
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
8 or 9 speeds ...... at that point I would think you are approaching the concept of the CVT ( constantly variable transmission ) used in some vehicles.
1 Post
R170 99SLK230 + SLK32
Yes - I've just been reading about the CVT's used in the B200's and some later model A Class. Although they are still refered to as 7-speed.
Were they the guinea pig for the 8-9 speeds?
b200 plus bmw, peugeot
The 7G-DCT gearbox is targeted to front drive, transverse engine platforms.
The new 9G-Tronic 9 speed automatic gearbox is designed for longitudinal engine mount models like the GL and can be used in rear and four wheel drive models.
Mercedes has already announced that the 9G-Tronic will be adopted generally across the range and with up to 1,000Nm of torque and already in use with the 3 litre diesel as used in the GL there is nothing to stop it being introduced at any time. The 9G-Tronic was introduced into the current e-class outside of a model refresh so it could happen with other models.
