X166 Emergency Handling - UNSAFE according to Review
http://www.autoguide.com/auto-news/2...r-reports.html
I wouldn't hold my breath. I'd also watch the video and see the "flaw" for your self so you can determine if it is really such a dangerous thing or just something that a small percentage of people might run into. In addition, you should consider that the behavior is potentially more desirable than the alternative. Keeping in mind the GL is a big family mobile, preventing a rollover is much more important in most situations than getting a double lane change executed in roughly two car lengths
think about it - even the 63 essentially has the same system..
i think its an appropriately safe feature and is to prevent roll over or turning back into the obstacle itself!
I agree...... I think (based upon all my reading and viewing the test ) that the vehicle is doing what the systems ( and their programers ) feel is the safest for that particular vehicle.
? According to MB: (http://media.daimler.com/dcmedia/0-9...0-0-0-0-0.html)And Citroën's similar system sure helped them beat the original "moose test", as I mentioned in an earlier post...
Yes, I definitely agree that it is better to keep the car upright, and if it would have lifted two of its wheels it would've failed even worse. The GL can't upheave the laws of physics, so of course it must fail at some point. The thing is, it fared worse than "some big, lumbering heavy-duty pickups" according to CR, which suggests the GL could perform better than it currently does without risking tipping over. Or maybe that's not the case and there is no problem, but since they've tried getting away with subpar performance in this kind of test before *cough*A-class*cough*, I think it would be a good thing if they'd address this.
Couldn't you say that it is a handling stability thing
? According to MB: (http://media.daimler.com/dcmedia/0-9...0-0-0-0-0.html)Reduction of body roll will in turn reduce movement of its center of gravity, which should make it less prone to tipping over. I think the ESP should be able to sensor that and take it into account, but it'd be great if someone could disprove or verify this.
Secondly, of course it is better to run into a ditch than to hit another car; but suppose you don't have that option and you didn't see an oncoming car before you avoidance maneuvre. Most people would probably turn left if they thought that lane was clear of traffic, instead of hitting a truck or a moose. Moose (and deer, although they're not as lethal) often come more than one at a time and I've been myself in the situation where I'd had to "slalom" between a pair of moose.
Besides, even if you would never do this maneuver you could still be the one facing a GL struggling to get back into its lane.
I'm pretty certain that it is a bad idea to turn off the ESP, since the ESP can do things you can't emulate as a driver. And I totally agree that we don't have enough information to say that the ESP is overprotective and can be "retuned" or whatever to fix this. I don't agree with it being an unimportant metric, though, and I think it is a difference between reaching the conclusion "the GL is bad at this because it is a SUV, and SUVs tend to perform badly at these kinds of tests" (which CR didn't) and "the GL performs much worse than expected, in fact the lowest score of any SUV we've ever tested" (which CR did).
Is this a scientific test?
Many unknowns.
1.They should get other year's GL s and test too. Also other 13 GLs.
2. sport or comfort mode?
3. 21 vs 19 inch wheels?
4.Adaptive damping yes or no?
and many more variables.
scenario was - freeway- without any warning boards or cones- there it was the big truck with the 'merge right' arrow- in the left lane going 5 miles an hour when everyones going 70+, 2 cars in front of me- muuuuch shorter distance to stop- needed to merge on left shoulder momentarily and then merge back onto the left lane..
yea- scaaaary! especially when the guy behind you is in a BIG truck going the same speed..
all i can say is thank GOD!!
Thanks for all of the great information on this forum, and Happy New Year!
I hit the brakes and swerved... The vehicle in a split second tightened the seat belts and added more braking.. The deer made it across but still tagged me at the lower LED light section.
My buddy and I were blown away how well the car enhanced the avoidance tactics that I used. You can't get anymore real than that.
You can have confidence in the car for sure.
IMHO, the GL is fine and my truck is scheduled for delivery to the dealer this week.
I don't expect a 5000lb vehicle to perform like a mid-engined sports car (something about physics) and ~13mph is a small spread. I'd rather hit something under control with the benefit of crumple zones and air bags than roll multiple times into other potential unmovable objects.
http://consumerreports.org/cro/2012/...ance/index.htm
I find that in Sport mode (when the active systems use the damper pressure and I think some active anti-roll bar pre-load) the body roll is negated. It does have a "you're going too far" mode where it starts to let the body roll over once it has reached some limit, but in general, without absurd steering input, you can maintain a much (much) higher apex speed without the car or passengers complaining at all. But be prepared for a firm, but not quite jostling ride.
I think MB needs to completely rethink their stability control in the X166. I don't recall any of this grief in the X164 and we drove with similar "alacrity" and I have over two decades of race experience as amateur with some lap records to my credit, so I'm not entirely without a reasonably mature opinion.
Compared to other Mercedes and a Cayenne Turbo S, the GL is a sublime handling SUV -- it is neutral and communicative at its limits. It does tend to work the front tires on the outside shoulder, but no surprise with the twin turbo V8 and transmission all wanting to escape through the straightest line exist at each tun. Still, with a balanced and progressive throttle, the 550 will set on its suspension, load up the rear and rotate correctly on a steady steering angle. The Cayenne needs exhausting finesse to coax it into this kind of transition, but the GL will find its way there and show you the way if you're a bit early or a bit late or a bit quick or slow. The BMW X5M can do a similar job, but it's a much smaller, shorter vehicle and very much compromised in ride comfort to keep it on its toes. The active handling of the GL is to be applauded. The stability control, well, it stays on, but I do turn it off for my own preference when I know it's going to be annoying and not helpful (such as the five miles of winding mountain road up to our house when I want to maintain a steady clip.)
I'd suggest everyone find a safe stretch of road off the public roads, say an old factory side road, and practice a comfortable left-right-left swerve avoidance, build up speed with confidence, have wide open run-off areas, then put down some cones and see how the car fares. First suggestion is add 5-10psi to the tires to the max load plate specification (remember cold pressure.) In my experience in the 550 with active controls, if you ease the throttle (which "tells" the computers you're not out of your depth) before/during the swerve, rather than a hasty life-off/swerve/panic brake (which will induce brake assist) you'll get a clean, controlled S path swerve around the obstacle.
Safety-conscious drivers should learn to drive, then practice driving in all conditions before encountering those conditions in an unplanned situation. I see this all too often where I live (mountain roads, snow, windfall debris ... things that a driver should have no trouble negotiating) and all too often I see a conscientious driver in an old 2WD car breeze through, then someone, let's say "not on the ball" will come blundering along ... mix in a little bad luck and you're in the ditch, or worse.
All that said, I'm on my third GL, approaching 100K miles, driven in extremely adverse conditions from sand to mud and blizzard mountain passes with 16 percent grades on metal studded snow tires and chains ... never a single fault or failure. This reminds me of the day we were literally blown sideways off the road onto the soft shoulder at about 30 mph by an unprecedented gust (in a valley) and the pre-tension of the seat-belts came on! I made a very light steering adjustment (coasting, almost zero throttle angle) and old girl just righted her course and we stayed out of the bank. I can't say my heart rate didn't "spontaneously increase my vigilance" but in that case, the stability system did it's job proudly and saved my bacon (no amount of car control short of being a rally car driver and taking risk between your gritted teeth can control a car when all four wheels are turning, slipping and drifting at once ... efforts to "catch it" usually only amplify the outcome adversely ... hence the strictly enforced rule in racing such as NASCAR or any banked circuit type racing, that any degree of slip and the driver is required to go "both feet in" ... meaning fully apply the brakes and fully release the clutch to allow the engine to keep running ... no margin for error, no consideration given to a skilled, professional driver being able to "catch it" ... so as a rule, by all means, lift off, but generally don't try to "turn into the slide" ... in modern systems, steer for your best outcome exit and resist the temptation of "negative outcome fixation" ... meaning "don't stare at the tree you're trying to avoid, instead, fix your attention on the path to a safe continuation without getting to know the insurance details of other drivers" ... : )
Bottom line, the appearance of the CR test is misleading, but that doesn't turn a blind eye to the flaws in the MB stability control.
