Issues with new 2013 GL 450
2013 GL450
Question on MPG
Just a general report on issues or the lack thereof....... finished a 400 mile trip yesterday ( will go back on thurs )....no issues! All systems worked as advertised ..... averaged 20.2 mpg at speeds ranging from 65mph to 80 ( ) 800 total miles on the meter now! Really like the intelligent headlight system and the Distronic Plus!
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Onboard......on my 2011, the difference between the onboard and "do the math" ran about -2 I'll do the math on the next leg of the trip coming up on Thurs.
2013 GL 450 & 2011 E350 Cab
I have MANY problems with my 2013 GL450 purchased in Oct 2012
1-Vibration at breaking , they have changed the rotors at 5000 mile now at 9800 mile same thing again!!
2-door lock issue which was also reported by few peoples in this forum !
3- vibration while driving very noticeable at 75 MPH. regular balance and rotation by dealer. Road force balance, Change 2 front tires, Road force balance again , changed all 4 tires and road force balance again now at 9800 mile still vibration exist and road force balance shows all 4 tires were off again
4- Ac stop working and or goes hay wire! dealers have received the alert but no fix as of yet !
5- issue with multi contour seats the massage feature was keeping the lumbar support back to zero on Driver side!
anyone else have issues as such ??
GL 450 rotor problem
I have same problem here at 6000 dealer replaced the front rotors and installed back the same brakes and the problem got fixed.Now at 10000 miles I have the same problem again . This is insane is driving me crazy .I have only one thing to say NO MORE MB is my first and last one.Going back to BMW love those cars.
#32
Gerti, good Luck with that. Just keep documenting it as soon as you see it happens again which it will! need to take to dealer , Unfortunately MB USA Inc , is not much of help either and they keep denying the issue . I just file a Suite under Lemon Law
best wishes , Please keep me inform of any other issues!
#33
#36
In NC the car has be repaired over 4 times for the same problem or in the shop 21 days within first 2 years. then you have to request the final repair request from the MB USA Inc ( which they declined it !) after that hire a Lawyer who specialized in Lemon Law 1
The process is a lengthy process and MB USA will drag it as much hoping the owner get tired of the problem and go elsewhere and trade the car! as some folks this is their only means of transportation ! good thing I have another car ! and if I have too I will park the car and get another car while process is taking place
Good luck !
Good luck !
#37
2015 Ram 2500, former 2013 GL350, 2007 GL450
Gerti, I don't have any first hand knowledge, but there were 2 X164 GL's that were lemoned with threads about the experience in the X164 forum. You should read them for background. One has the subject of 'wind noise' by a person with the name TamZ. The other is from Momsbenz. It's not easy, it takes persistence and it takes extensive record keeping. TamZ got a buy back and went to a QX56, Momsbenz, took another GL and I think is now happily on her 3rd GL.
The lemon laws are state laws, so assuming you live in the US, you need to look up the laws in your state. They have criteria that must be met. In all cases this is really a legal remedy to the problem. You will have to provide the burden of proof as to how you satisfy your state's lemon law. Since MBUSA is the adversary in your legal battle, they will only do what is legally required, and will take their time doing it. Your dealer may align with you, with MB, or try to remain neutral. Their position will depend on their relationship with you, whether they expect future business, etc.
If you proceed I'd suggest starting a thread for your situation alone. We'll provide help, advice, moral support, etc. You will need it to get through the process. Good luck!
#38
LeicaMan - what was your A/C issue? just curious
a few weeks ago i experienced a weird A/C blip. when i turned on the car, none of the A/C controls were lit or working, and it stayed that way for about 1-2 min until it just decided to turn on again. after it turned on by itself, it was back on the setting i had left it when i parked and working normally.
that was the only incident and thankfully it hasn't happened again because it's summer and cabin gets so dang hot.
#39
#40
The Climate control "issue" is solved by wiping the programming and doing a fresh install - the programming process takes about 2hrs uninterupted...
I have seen "some" brake problems requiring rotor replacement - techs also need to "enter" request for fresh pads on that warranty service request - which gets uploaded and approved by MB - if tech/service doesn't "enter" the pad request then fresh rotors with "oroginal" pads can cause reoccurence with fresh rotors.... there were some "iffy" rotors from Fall .. shipped in from Germany they don't have coating/protection and open toro surfaces from storage "seem to me" to have caused some contamination issue.. my best "guess"... on "vibration" I have seen one GL wheel with "micro cracks" meaning the structural integrity of one wheel - in this case a front wheel - was compromised and was a b*tch to diagnose but rotating wheels and specific extended road testing identified that wheel which MB Fedx'd in from Germany for replacement under special/dealer/request/super-VIP expedite.. I have not personally seen door lock problem..personally have not seen seat/lumbar problem..
#41
I'm kind of getting a wind noise at 30+ MPH. It feels like a window is partially open. I'm not sure if I can term it as vibration but I hope everyone understands how it feels when a glass is half way down. Does this have something to do with rotors/brakes as many have this problem here or is this some new problem? At higher speeds of 80+ its gone! Any inputs!
Also I've a rattling sound from the passenger side as if something loosened up! It happens only when I go over small bumps or potholes. Thanks!
#42
#43
Don't have a comment on the wind noise.....But re: rattles - rattles on this vehicle can drive you crazy, not because the vehicle has loose parts, etc. but because they can be caused by something as simple as a pair of sunglasses sitting in the cup holder, a ballpoint pen in the passenger door pocket, etc. .....any small object can like that ( I have had 'em!) can vibrate against the plastic and make a sound far louder than you would expect. In addition....the acoustics of the vehicle make the sound "appear" to be coming from where its NOT.....what I thought was coming from the overhead console was actually coming from the cupholder and what I thought might be in the glovebox area was in the door pocket! In short.....you will need to take a look around, maybe with a passenger! Every "rattle" I have had on this one and on my previous model was due to something I had introduced..... nothing on the vehicle. Good luck!
The wind noise is definitely an issue and its there from day one. Recently my friend was behind the wheel and asked me if there's a window open in the back! I may have to visit the dealership.
#44
Brake problem
My Gl 450 2013 has only 7k miles.. and it looks like it has a problem with the brake.. On the local is hard to feel it, but when i speed up on the free way and push the brake pedal my car vibrates in a unsafe manner..
I will go to the dealer in a couple days.. lets see what they say..
#45
#46
Thanks for the info~~ I will make sure to replace the rotor and the pads~~
