drilled back rotors?
Old 04-05-2013, 10:06 PM
JimBarnhart's Avatar
2015 Ram 2500, former 2013 GL350, 2007 GL450
Originally Posted by cookstar
According to MB Canada:
All GL's produced after December 2013 will have the solid disk brakes and NOT the drilled brakes, my production was February 2013 which falls into solid disk production.....
My gl350 was built in October of 2013 - no holes.
Old 04-05-2013, 10:31 PM
sraza's Avatar
MBs
u mean 2012.. also one the prior message- it means cars built after dec 2012 right?
Old 04-06-2013, 10:16 PM
oops, yes, October of 2012.
Old 04-07-2013, 12:16 AM
cookstar's Avatar
2005 ML350, 2008 GL320, 2013 Gl350
yes November 2012 not 2013, my apologies
so if Jims car was built in October.... that would mean it would have to have it?
Old 04-07-2013, 09:22 AM
sbkim's Avatar
Various
This is just a wild conjecture but I noticed that breaking power on my new GL550 doesn't feel inspiring. Per Motor Trend reviews, breaking performance is very good and I presume those launch cars had drilled rotors and probably a ringer engine I am curious if lack of drilled rotors in the back is contributing to lack of braking performance.
Old 04-07-2013, 10:03 AM
cookstar's Avatar
I think that a larger surface area results in better braking, not sure if the drilled rotors have a larger surface area? but I read the actual "holes" would be for heat dissipation which makes little to no difference in everyday driving, but are visually much more appealing.
Old 04-07-2013, 10:18 AM
  #32
JoeMa's Avatar
23 EQS 580 SUV, 19 X7 (sold), 17/14 GLS550 (sold) 13 GL550 (sold)
The purpose of drilled rotors is to reduce heat under heavy use. Drilled rotors would likely not improve braking performance in normal everyday use. MB's decision to drill the front rotors only on the GL is most likely because the front brakes do most of the heavy lifting (or braking) when it comes to slowing or stopping the vehicle. The back rotors would rarely over-heat.
So I agree with Cookstar, solid rotors, while not as sexy looking, would provide a larger surface area and therefore better braking performance.
Old 04-07-2013, 12:23 PM
  #33
sraza's Avatar
MBs
just wondering if the drilled rotors do a better job keeping water and moisture off which would improve braking too..
Old 04-07-2013, 01:14 PM
  #34
cookstar's Avatar
I dont think that really matters since when the rotors sense water the pads skim over the rotors to dry the rotor, BUT that being said I know slotted brakes remove water better than standard disks.
The "brake drying" function ensures that full braking power is available even under wet conditions. And with the "priming" function, the system reduces the brake response time.
Old 04-07-2013, 06:10 PM
  #35
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Exactly..... the front rotors are the ones that are involved when the "lane keeping assist" activates as well as the ESP system and the "cross wind stabilization program".... I suspect all of that figures into having drilled rotors in the from. Also.... with those systems active, it will be interesting to see if there is increased wear on the front rotors. I have been amazed at the durability of MB brakes on my past two GL's!
Old 04-08-2013, 10:33 AM
  #36
cookstar's Avatar
it looks like MAYBE in Canada if you do not have the sport package the front disks will not be drilled either.... saw two today without the sport package with no mb logo on the caliper or drilled rotors.... again this could be a couple of vehicles or all....
Old 04-08-2013, 11:01 AM
  #37
vertrkr's Avatar
2014 GL350 ordered
My neighbor ordered a 350 which he got last month and neither the front or rear are drilled.
Old 04-09-2013, 10:40 AM
  #38
For clarity, my US based 2013 GL350 that was built in October of 2012 doesn't have drilled front or rear rotors.
Old 04-09-2013, 02:36 PM
  #39
blittle's Avatar
....and my GL450 was built in Feb. 2013 and has drilled front rotors only
Old 04-09-2013, 10:16 PM
  #40
Mbenz260e's Avatar
2021 S580 Prior: 2012 E350 Bluetec, 2013 GL350 Bluetec, 2009 ML320 Bluetec, 2006 E320 CDI, 1987 260E
Nov 2012 build GL350 no holes front or rear breaks. Doesn't really concern me at all since its the mamma wagon anyway. Is interesting how they are switching things up so soon...
Old 04-12-2013, 12:24 AM
  #41
sraza's Avatar
MBs
got a call from MB corporate today- she listened to the entire issue and concerns of why the difference in same model year with no mention of this anywhere..
She wasnt sure why the difference and I mentioned that its was advertised in a way where we all felt that rears should be drilled as well. (had to explain what drilled exactly means)
She will do some research on this issue and get back to me- i mentioned that since it is available on same model year and different models ( not specific to a particular model) that should we expect a change (something like, though not really, like a recall)
will let you know when i know...
Old 04-12-2013, 01:05 AM
  #42
Dalema's Avatar
GL550
U.S. GL450 built Oct 2012 - drilled rotors front and back
Old 04-12-2013, 09:11 AM
  #43
cookstar's Avatar
thanks for contacting mb as well, keep us updated!
Old 04-12-2013, 09:30 AM
  #44
What size tires/wheels do you have Dalema? Wondering if it's related to that?
Old 04-12-2013, 09:57 AM
  #45
Dalema's Avatar
GL550
I have the standard 19" wheels with the crappy (in the snow) contis.
Old 04-12-2013, 10:29 AM
  #46
sraza's Avatar
MBs
thats soo weird- so its defintely not a part of appearance, 20/21" wheels, ADS, or off road package or active curve package..
no idea why this difference- strange......
Old 04-14-2013, 09:19 PM
  #47
I have the 21" wheel package and don't have drilled rotors. Maybe it's only part of the base wheels? Doesn't make sense, but just a thought.
Old 04-16-2013, 09:28 PM
  #48
sraza's Avatar
MBs
mb corporate called yesterday-- still no idea why the difference.
I was told it should be standard with amg package which I immediately confirmed that it is not as several 550s do not have it and some without amg package have it and it has nothing to do with off road package..
they spoke to MB technical staff and were told that without VIN numbers it is impossible for them to be able to identify the difference..
so I guess the only way we'll know is to provide vin number of cars with and without rear drilled rotors to be able to find out why the difference....
Old 04-16-2013, 09:33 PM
  #49
cookstar's Avatar
I gave my vin and that still got me no where....
Old 04-16-2013, 09:37 PM
  #50
sraza's Avatar
MBs
thats strange-- really- i mean this makes no sense at all whatsoever...
Quick Reply: drilled back rotors?
