Cold Feet
Old Jan 2, 2014 | 10:58 AM
JimBarnhart's Avatar
2015 Ram 2500, former 2013 GL350, 2007 GL450
Cold Feet
Not the idiom, reality.
This is my 3rd MB ('03 ML, '07 GL, '13 GL). I typically leave the climate control on 'auto' and just adjust the temperature as I need for hot or cold days.
I have found that on my '13 GL when I set the temperature via auto in winter, I can be comfortable from my waist up, but my feet get cold. It is much cooler in the footwells. I typically have to switch to manual to push more air to the floor to keep my whole body comfortable.
Has anyone else seen this? I'm wondering if it's normal, or if I should have my dealer look for a blockage of some sort in the floor ducts.
Old Jan 2, 2014 | 11:19 AM
a330captain's Avatar
2014 GL350 , 2010 Accord V6, 40' Monaco Dynasty RV, 1971 VW Convertable
Jim
Are you complaining that you are now having a REAL winter. I No longer live there.
Old Jan 2, 2014 | 02:40 PM
We are definitely having a real winter this year! For the past week our high is 1 degree fahrenheit!
Old Jan 3, 2014 | 09:20 AM
Bob Burket's Avatar
17 AMG CLS63S; 21 AMG GLS63
My feet were cold too.
I was playing with the system and found that the rear zone was off auto, and the fan was set to its lowest setting. (Obviously I have 3 zone system.)
Once I turned the rear zone to auto and set it to the same temp as the front two zones... everything was good!
Old Jan 12, 2014 | 08:30 PM
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Its normal…..but I don't like it , and my wife REALLY doesn't like it!! I go to manual as you do. After a few minutes of run time , it seems to balance out and I switch back to auto…….. no issues in summer.
Old Jan 12, 2014 | 09:59 PM
I don't have 3 zone, but I do have some control of the back seat because of the heated seats. I put the back console to push the heat to the floor instead of the body and find it helps some.
Old Jan 16, 2014 | 05:55 AM
doctorG's Avatar
2013 CLS550 4Matic; 2014 GL350; 2015 GL63; 2016 GTS; 2021 G63
Personally, I've found this to be an issue in my old S-class, the GL, and our CLS. The auto feature does a lousy job in the winter keeping your whole body warm. Either I get good heat up top or at my feet. I used to get annoyed that my wife would change the setting to manual and choose where she wanted the heat, but I do the same now. It works much better...shouldn't really be that way, but ???
