Question about 3-zone operation
All other vents work well and blow forceful when on high. Not so with what I would have considered the main vents for the 2nd row.
Any idea what I'm doing wrong?
Thanks!
Thanks!
What I have found is that once you have activated the "zone control", to get more air out of those vents, the 2nd row passenger has to manually increase the fan speed. AND…. in the cold weather the main air flow is coming from under the front row seats anyway. In hot weather ( AC on ) is when you get max flow from the center console vents. Because they have included the side pillar post vents and roof vents in the 2nd row, the flow from the center vents is not what you might get from a vehicle ( such as the previous GL ) which does not have those additional vents.
We test drove a GL450 without the 3 zone and it have plenty of flow from the center vents, so that's why I felt something was "off"- well that and the fact that our vents just did not have any flow to speak of.
I guess it is a non-issue as long as it's cold outside anyway. If it doesn't work as you described when the weather warms up, I'll revisit the issue and take to dealer if necessary.
Thanks again!
Thanks again!
