2014 GL450 Wiper Problem
Is anyone having problems with the driver's side wiper wobbling on the lower half of the wiper? I've taken it back and had the wiper blades replaced twice. I have less than 6K miles on it.
2005 ML350, 2008 GL320, 2013 Gl350
Yes same issue with mine, its not the wiper itself its the arm that needs to be adjusted, it still does it a bit but 80% less. I had mine replaced twice until they figured out it was an adjustment issue.
99 E 300TD, 02 E320, 2013 ML350
There is a special tool that connects in place of your wiper blades and we adjust the angle to the windshield with it. There are certain specs and sometimes the arms need to be adjusted to the higher/lower end of the specs. I have done many of these and its something that the dealer will have to mess around with to get it right. Once you get the "sweet spot" I have not had any come back with this issue.
