Parking assist question
Use Active Parking Assist for parking spaces:
- that are parallel to the direction of travel
- that are on straight roads, not bends
- that are on the same level as the road, e.g. not on the pavement
http://www.mbusa.com/vcm/MB/DigitalA...al/2015_GL.pdf
While in reverse select from the icons at the top of the display to get the most useful view of the parking space, e.g., looking at the rear tires or the front tires or the rear bumper, etc. You will be able to watch your tires, the lines on the ground, if there are curbs or other obstacles and surrounding vehicles. Slowly back into the space while switching views with the COMAND controller knob. Just remember that you have to be rolling before turning the steering wheel will have any effect.
I use this technique to back into the garage while keeping it centered on the Traxtile floor and maintaining clearance front and rear for the garage door to close and the rear hatch to open:
https://mbworld.org/forums/gl-class-...ml#post6491875
Personally ... I wouldn't trust an automatic system to park my car as the consequences of a mistake are too high. The visual aids provided by the 360º System are useful and intuitive, plus the driver has complete control.
Regards,
SaniDel
Aceman
