Trailer lights blinking
Old Dec 17, 2015 | 04:31 AM
Dog hauler's Avatar
GL350
I have a 2014 GL350 with factory towing package. When the trailer is connected via the 7-pin connector and the ignition is off with all lights on the GL turned out and the smartkey not in/near the vehicle, the trailer lights (LEDs) nonetheless blink randomly but frequently.
This problem occurs with two different trailers I own. Why is that happening and what can I do about it?
Old Dec 17, 2015 | 10:59 PM
fabbrisd1's Avatar
A gaggle of MB's
Interesting - "sounds like" the CanBus ion sleep mode is doing a circuit sweep.
If you don't have a harness connector/adapter with the built-in added resistor - about $14-$16 - you could try that to see if that added resistance/load changes the behavior...
Old Dec 17, 2015 | 11:24 PM
Dog hauler's Avatar
GL350
Is this what you're talking about? http://www.etrailer.com/Accessories-...ALEDRST1B.html If so, how/where do I wire it in? Sorry for my ignorance on that point.
Old Dec 18, 2015 | 10:43 PM
fabbrisd1's Avatar
A gaggle of MB's
I was refering to Tow Ready TR20141 - about $16-$17
http://www.rvautoparts.com/20141-Tow...FQ-RaQodqqkL7Q
Old Dec 21, 2015 | 11:15 PM
Dog hauler's Avatar
GL350
I get the resistor part, but I have a 7 pin connector. Why would I want to use a 7 pin to 5 pin adapter?
Old Dec 22, 2015 | 05:06 AM
JMCarter's Avatar
2013 GL350. BMW 335. 2014R1200RTW
Had the same problem with my GL towing an Airstream. This will make it clearer. Just put one of these on the wires leading to tail and blinkers and you're done.
http://www.etrailer.com/Accessories-...230004C-2.html
Old Dec 22, 2015 | 04:43 PM
Dog hauler's Avatar
GL350
That sounds easy enough, but what about the various running lights? They blink also. And pardon my electrical ignorance, but exactly where would these be spliced in?
Old Jan 24, 2016 | 10:34 AM
LAZARU5's Avatar
2025 E53 Hybrid
I think the Tow Ready 20142 adapter will work for your application.
http://www.towready.com/products/ele...nKH1VxuIkGzeQ9
