Battery questions
A healthy battery will handle it just fine.
It's interesting to see how the fuel pump, steering, brakes, etc. effect the power consumption while you are driving. It's also interesting to note the time it takes for the battery to be fully charged after you start the engine. I've noticed it charges around 14.7 volts until the battery is back to normal and then it maintains 12.6 or so until you shut the engine off. If it drops below 12 volts, you don't want to be powering accessories with the engine off.
