2013 GL450 WTF is this noise?
Old Jul 7, 2016 | 12:01 PM
gsobol's Avatar
GL450
Did anyone ever experienced this type of noise coming from under the hood? Engine is off (have been off for at least 30 min), engine fan is off, accessories are off, in effect NOTHING is on. Dealer doesn't know what it is either.
(Turn the sound up)
http://vid296.photobucket.com/albums...%20noise_2.mp4
Old Jul 7, 2016 | 02:50 PM
LIRS6's Avatar
'14 GL550 , '79 911SC
Wow, that's odd - what happens if you disconnect the battery?
Old Jul 7, 2016 | 06:06 PM
Steve Maislin's Avatar
2013 GL450
It's alive! Very weird.
Old Jul 7, 2016 | 11:18 PM
gsobol's Avatar
GL450
Nope, it stopped after about 10 min. Could not replicate. No idea what under the hood could make this noise. It sounded like an electronic beeping, although it could have been made by escaping air or anything else releasing high pressure (all speculation). Funniest part, dealer has no clue what it could be either.
Old Jul 8, 2016 | 12:15 PM
grumpywings's Avatar
'13 GL350 Bluetec
Air/hydraulic bleed down, likely from the brake booster. Turbo engines usually have a system that provides vacuum or pressure for power brakes, but that pressure bleeds down when the car is off. Normal.
Old Jul 8, 2016 | 11:05 PM
gsobol's Avatar
GL450
Thanks !!! That's a first explanation I've heard that makes sense. The noise was more concentrated on the driver side, where the break booster lives . Since the dealer didn't know what it could be and there appears to be no ill side effects, I'll go with this unless someone comes up with a better one
Old Jul 9, 2016 | 07:44 AM
mtm's Avatar
mtm
gl450
Could be the auxiliary coolant pump (sometimes also called afterrun pump) - helps circulate coolant at low RPM and after the engine is off, if certain conditions are present.
Not sure where it is on this engine, but look for a cylinder with two coolant hose connections.
