Engine Air Filter Replacement - Bluetec 2015
Old Sep 11, 2016 | 08:26 PM
troutdog99's Avatar
2015 GL350 BT
Has anyone done this DIY yet? I'm looking at the placement of the rear Torx screws and they seem incredibly hard to get at. Any suggestions?
Old Sep 12, 2016 | 03:30 PM
#2burners's Avatar
2014 gl350 designo
Have done mine. You will need to use a 1/4" swivel adaptor , 1/4" extension and the correct torx bit. It indeed is tight back there. FWIW once loosened to where you can pull it out of the housing i found that leaving it in will prevent you from possibly dropping it as i learned…Its hard to grip and remove from back there if you have big hands.
