BiXenon Headlight Low Beam Out
I have not replaced an HID bulb before, but after some initial research, it appears access through the wheel well may enable replacement without removing the headlight assembly. Has anyone else attempted a DIY replacement? Are there any tips or watchouts?
FWIW the Xenon lights are fantastic…even with the passenger side dark, I can see better than in some previous vehicles during normal operation!
If interested, we carry higher end Morimoto D1S replacement xenon bulbs available in 5500K (pure white) and 6500K (white with a slight bluish hue) if it does turn out to be a bulb related issue.
Also, if it is a bulb issue, it's advisable to replace both at the same time to ensure even break-in/life so you won't get kelvin temp (color) matching issues on both sides.
