37K miles..class B service advice?
Are you also too lazy to open up the manual to find out what things need to be done at what mileage points according to the chart in that book? It doesn't matter what the dealer tells you, what you need to do for maintenance is what the book states is required. It has nothing to do with mere warranty coverage only, and everything to do with preserving your vehicle in general and beyond the coverage period. Filters and fluids, including brake and trans, eventually need replacement.
You need not get the work done at the dealer, if that's what you're trying to avoid. Just keep your records showing that you did the work at the required intervals.
