Remote Starter GL 450
my main gripe is if you have Keyless Go (P2) package, you have to remember to hit the Start button before stepping on the brake once you get in the car. If you do not do that, it just shuts down. And when you remember to do that, there is a 5 second pause for the car to "start up" and the A/C shuts off during that pause (which is usually the reason you want remote start in the first place). just a slight nuisance though.
also, yes, you can also remote start from your key by pressing the panic button once. however you must be in range of the car with the key, which is why i opted for the Drone Mobile so i can start it and let it run for 15 minutes when the the car has been sitting in direct sun all day.
https://www.ebay.com/itm/23256147927...84.m1558.l2649
OEM Remote Engine Starter SmartKey Keyless Entry Kit Mercedes-Benz + Smart Phone
Make sure dealer installs it.
