Jacking the car and using jack points for jack stands
I saw only 3 threads on jacking up the truck but none of them address my concern.
I just got a 3 TON jack from Harbor Freight. I want to jack up the car and still use jack stands at the jack points that are designed for the truck. However, when I lift the truck using the jack, there is no room to put the jack. Is there another place i can use to lift up the truck, say somewhere in the front center so that i can put the jack there?
there's plastic paneling so i can't find a cross member.
Thanks.
Thanks.
wheel of front passenger.
This is on a 2013 GL550
This used to be a recommended way to remove the wheels on air suspension Citroens back in the day, and I've seen a few videos on Youtube people doing it with Airmatic sedans.
If only I could figure out the jack points on this car, I could do the same.
