Disassemble Running Board - Help
#7 - Step Plate
I need to replace the step plate (refer to image). I'm thinking of replacing just that instead of getting the whole running board.
On my side - my MB Certified Collision Center disassemble the running board - pop out the rubber bumper things - and repaint in silver using wheel paint with top coat - I have had some customers also get powder coated ..
I just spoke to one of the mechanics at local Mercedes, he said the same thing; that is to pop out the rubber bumper (#8 in the picture - Step Plate Clip). He also said that you will most likely break the rubber bumper and the washer (#9 in the picture - Step Lock Nut) in the process of disassembling it.
To replace #10, you need to remove the whole running board. These youtube video clips might help:
Hope this helps!
Btw, I suspect that the support cracked when someone tried to jack the vehicle up from underneath the running board (I am the 2nd owner).
