Starting issue just clicks, then starts
It has problems when I go to start it, it usually just clicks, if I recycle the key it either single clicks again, or it cranks and starts.
Sometimes it may click 2 or 3 times then crank and start. Other times it can take 6 to 10 cycles of the key. It always starts in the end but its a PITA going through the clicks each time
I have tried a different battery, same result. Checked all ground points that I can find, all seem fine.
No errors are showing in xentry.
Please can someone suggest the next thing to try to help pinpoint this
thanks
All repaired now and no errors anywhere apart from this darned starting headache.
If you really mean to describe using the Keyless Go Button - with foot on brake - you need to press down all-the-way - and release - a click/click/no-workie is a system of two things - not pushing the button all the way down - or not having your foot firmly on the brake when starting. The button needs to go down to full bottom before release - it is not "slap-it-and-go"
