Rear brake light
Old Jun 9, 2018 | 05:16 PM
MNMBbuyer's Avatar
na looking to buy
Rear brake light
Hello have gotten great advice here! Need to replace rear brake light.....is this doable on my own (I’m not a mechanic)?
Thanks for the directions!
Old Jun 9, 2018 | 06:18 PM
black06c230's Avatar
mgLipGD
The reg outer lights?!? Very easy.
Old Jun 9, 2018 | 06:36 PM
MNMBbuyer's Avatar
na looking to buy
Rear brake light came on dash....
Old Jun 10, 2018 | 12:14 AM
mgLipGD
Easy to remove the side panel and remove bulb. Takes maybe 5min. Helps to have something to pry the panel from the top of the driver side. Don’t recall the pass side being hard
I swapped mine out with LED.
Old Jun 10, 2018 | 09:02 AM
MNMBbuyer's Avatar
na looking to buy
Thank you!
Old Jun 10, 2018 | 01:39 PM
maneesh's Avatar
2013 GL450, 2023 Tesla Model Y LR, 2024 Outback L XT
MNMBbuyer,
Here are two videos on how to replace the bulbs - very DIY. If you are going the LED route, you will require resistors.
Old Jun 10, 2018 | 02:39 PM
mgLipGD
Another option over resistors is to just wire in a 1156 bulb socket and move the factory bulb to it and put the LED bulb in the factory holder. That’s what i have always done as simple and resistors have given me issues.
Old Jun 11, 2018 | 10:57 AM
vivaitalia's Avatar
2013 GL450
could you re-explain what you mean by wire in a 1156 socket? Just curious, as I've already replaced my halogen bulbs with LED with canbus and the 2013 model year uses a 1156 socket.
Old Jun 11, 2018 | 05:21 PM
mgLipGD
if using canbus bulbs then no need to wire anything in.
But to answer you get a 1156 or what size needed socket with wires and just tap into the stock wires to the bulb you are replacing. Move OE bulb to new socket and put LED in the OE socket.
Old Jun 24, 2018 | 07:28 PM
PuLverIZA's Avatar
E400,GLK350
Thanks for the great post maneesh, i was able to replace the rear tail light on my 2015 GL450.
Old Jul 15, 2018 | 04:22 PM
htce38's Avatar
S, GLS
I found these LED bulbs to be a perfect swap, no error code, no hyper flash, instant on and much brighter. 5 mins plug and play swap.
Amazon Amazon
Old Jul 16, 2018 | 09:08 AM
vivaitalia's Avatar
2013 GL450
These were the ones I used about a year ago ... no errors ... at the time it was the highest lumens (~1,500) I could find that didn't give me error codes ...
https://amzn.to/2PBm96R https://amzn.to/2PBm96R
Old Aug 25, 2018 | 12:21 PM
cadetdrivr's Avatar
2014 GL350 / 2026 BMW iX iDrive60
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
FWIW, I tried these bulbs for the brake lights and it resulted in error codes on both sides.
YMMV.
Old Aug 25, 2018 | 02:57 PM
vivaitalia's Avatar
2013 GL450
I got no error codes with these on my 2013 GL450
YMMV.
